Old 05-13-2019, 03:35 PM
And I think we all agree it is running rich
Old 05-13-2019, 06:38 PM
jcsmith jcsmith is offline
Nice tractor and some nice options. Good luck. Definitely read the manual. It will answer most, if not all your questions and then some.
Chris
1968 104 , service replacement '96 K301, 42" deck
1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck
2007 LA130,21hp Intek v-twin, 48" deck
As you slide down the banister of Life, may the splinters point in the right direction .
Old 05-18-2019, 05:07 PM
ethanw ethanw is offline
Awesome! thank you so much for the info and support. I will do what you suggested.
Where do I start looking for a seat?
Thanks!
Old 05-18-2019, 07:03 PM
jbrewer's Avatar
jbrewer jbrewer is offline
You can post a "want" here on the forum. There's always Ebay, and Tractor supply if you just want something to sit on, as opposed to original .
I'll share that if that is indeed oil burning ( we wont know till you get the engine running right with some carb work) , oil is very cheap AND it'll run a very VERY long time using a little oil (if you check it before you run it)
Thanks for sharing it!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 06-04-2019, 05:59 PM
Update:
When I started it after my last post here it ran as it always does... then a few minutes into that the RMP increased on its own and seemed to run more smoothly. I lowered the throttle a little to bring the RPM down, brought rpm down, then it died. It would crank and not start, with throttle fully open to fully closed i moved it up and down and cranks fine but no start.
this happened on a slight uphill.
let it sit a day, then started it, started on the first attempt.. Then the same happened. Except this time when cranking it started to puff out black smoke, and it seems as if it is about to start running but it never does run on it's own.. Crank crank and nothing, then i lower throttle to the middle, and it seems like its about to take and puff putt white to black smoke and just wont keep going on its own if i stop cranking engine stops, doesnt take.
What should I do?
Old 06-04-2019, 06:50 PM
Remove the Carb. Dismantle the Carb. Clean the thoroughly. Reassemble and adjust per the Service Manual.
Old 06-04-2019, 07:44 PM
sawdustdad's Avatar
Northern Tool sells a nice seat advertised to fit cub cadets. It's what I've been putting on many of mine.
https://www.northerntool.com/shop/to...9222_200519222
Old 06-04-2019, 07:49 PM
I agree although I’ve gotten the same one cheaper at rural king and they come in black or yellow. I did buy the Northern seat Frank pictured in the past and it held up well.
