Old 08-11-2010, 11:03 PM
Roy Najecki's Avatar
Roy Najecki Roy Najecki is offline
Matt - thanks!
While we are talking about reducing slop and friction, has anyone tried using or making UHMW (Ultra High Molecular Weight polyethylene) washers? This self lubricating material is used by woodworkers to make jigs and drawer slides, so the wood slides easily over the surface.
Grainger and Amazon.com sells it in 5mm thick self-adhesive tape for under $7.
I was thinking of its use anywhere Cub Cadet has a thin plastic bushing, this stuff might work much better.
Old 04-24-2011, 01:02 AM
cub108 cub108 is offline
my trunion bracket looks like zelda's. Except, both corners are worn so bad from the spring end caps they are super close to going right threw the little metal that is left.
1. What will happen if this problem is not repaired and the end caps go threw the metal?
2. When the trunion bracket is repaired, can I reuse the springs and end caps?
Thanks for the help again.
