Old 03-09-2019, 07:02 PM
CubbyRI CubbyRI is offline
I could sleeve it myself, but as I said, lot of work (plus a few bucks for the tooling). Well some work anyway. But with that amount of free play (40 thou more or less) what does that do when riding it? Would I feel it somehow?
Originally Posted by ironman View Post
From your video, that axle looks to be shot. I think a shop would have to sleeve it and the cost would probably be ridiculous. There are axles and spindles on eBay as we speak. If your wheels work good on the spindle that's not bent, put new bearings in 'em & use them.
Model 100 Dec 2020 - Running condition, has snow plow!
Model 123 Nov 2020 Hydro needs much work, or resto, building front end loader for this one
Model 100 Feb 2019 apart for total frame-off / sandblast etc resto
Model 70 Sep 2020 needs total resto and an engine, or for parts
Model 70/100 Mar 2021 buried in rust, frozen engine, got free for parts.
two spare hydro rears
"in for a penny, in for a pound!"
Old 03-09-2019, 07:07 PM
Thanks George thats very helpful to know. I'll give that a shot when I can find a long pipe and sturdy hole to stick the spindle through.
Well if it were me, I'd bend it cold.
Spindles are normally case hardened to resist bearing area wear and toughen them.
When you heat them you loose that.
It got bent cold, so straighten it cold.
Old 03-09-2019, 07:10 PM
ironman thats incredible, thanks! looks like replacements that are not all pitted should turn up fairly quickly if I keep my eyes open.
The narrow wheel used on the 100, p/n IH-386188-r92, was used in a total of 31 applications, including trailers. FYI, here's the list....
https://www.cubcadet-parts-direct.co...vailable-Wheel
Old 03-09-2019, 09:31 PM
dale c. dale c. is offline
put it back on the tractor and put a jack stand under the end of the axle put a pipe on it and stand on the pipe
Old 03-09-2019, 09:35 PM
Old 03-25-2019, 09:27 PM
OK here's a little update, I got the wheel "bearings" out using a big bolt as a drift. They are actually solid bushings. My new wheel bearings appear the same size but until I try to press them in, wont be sure.
Also, bought a used right spindle and wouldnt you know it, that was bent too! Seller refunded me. I'll just do the pipe trick.
Old 03-26-2019, 07:11 AM
Just hope the hubs are not stretched to the point they won't hold the new bearings.
Good luck!!
