Old 03-01-2018, 01:54 PM
After that ordeal, I'd chuck that thing as far as I could and not look back, lol.
Silicone that rear cover on and get this project done! Forget that gasket.
Old 03-01-2018, 02:57 PM
Marko141's Avatar
Marko141 Marko141 is offline
At this point I just may do that, I think I'm going to wait for that gasket, it's coming either today or tomorrow, I already paid so I'm just going to wait, what's another day.
So ik it says 7 quarts but how do you truly know when it's full? Let's say it has a small leak and someone wants to just add a little oil every so often, how do you check?
Cub Cadet 127, 1450, read bottom plow, blower, tiller, wheel weights, chains
Old 03-01-2018, 03:10 PM
It's full when it starts to run out of the fill pug in the rear cover.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 03-01-2018, 04:32 PM
Marko141's Avatar
Easy enough, nothing over complicated lol
Old 03-01-2018, 07:19 PM
ironman's Avatar
ironman ironman is offline
This thread should become even more entertaining when he goes to fill it.
Old 03-01-2018, 07:30 PM
I use the tube from a jug of DEF ad a funnel suspended from the seat frame.
That is unless I have the fenders off in which case I take the cover off the transmission case and just dump 7 qts in and button it back up.
Old 03-01-2018, 07:39 PM
twoton twoton is offline
....... busted out one or more of the tapped cones inside the case and that's what's causing the leak.
The previous owner of my 1450 busted out one of the tapped cones with a too long bolt so I made some studs out of some 3/8" hot dipped galvanized bolts that I had and glued them in with some red lock tite.
Old 03-01-2018, 08:50 PM
Bamafan Bamafan is offline
Inactive Member
Default easy way to fill rear no mess
I use this to fill the rear, no fuss no mess. Just fill a quart oil bottle with oil and pump it in.
https://www.walmart.com/ip/Shoreline...-Pump/35259578
[B]Larry[/B]
Old 03-01-2018, 08:55 PM
Inactive Member
Thought I would help him out on this one Ironman
[B]Larry[/B]
Old 03-01-2018, 10:59 PM
Marko141's Avatar
Just trying to boost some activity on here... but I admire the thought.
