#21
Very well done! If it weren't being used while it's cold out, would oil temperature be a concern? I have thought about a hydraulic pto for a long time, but didn't know where to mount a oil cooler where it wouldn't look rediculous.
Side not, isn't 15 foot lbs about the same torque as a 12 hp k series puts out?
1- 1864 Dual hyd, cat 0, axle braces 1- 1450 Dual Stick w/ power steering 1- 1200 in pieces 1- 1864 in pieces QA36A Thrower, #1 Tiller w/ extensions, IH windbreaker, IH wheel weights, 44C mower deck, 50C mower deck, CCC 54" Blade, GT46 high vacuum deck, GT54 deck, Cub Tripple Bagger, Custom dozer blade, Custom suitcase weights, 3pt cultivator, lawn sweeper, original R-Bucket |
#22
Oil temp was a concern, not only for the blower but my backhoe as well. That's why I built a second oil tank. The kwik-way tank only holds about 1.5 gallons. I built another 3.5 gallon tank to keep things cool. I have it set up so both tanks are being utilized. I have since moved the oil filter to a more suitable location.
127 - 48'' deck + tiller. 1512- 46" GT deck & bagger 1872- 60" Haban 1772 turbo diesel- Iron rear + KW loader + backhoe + 3 point. Case 580CK Ford 850 International TD-8E |
#23
Ken, where did you mount your filter? I'm in the process of doing the same loader on the same tractor and have not found a place yet that I'm 100% happy with the location. Nice job on the auxiliary tank.
#24
It's on the side of the loader frame on the return line in the above pic Todd...... Did you miss it?
#25
Awesome build. Very impressive.
Don 882D 50" Deck Mower 54" Snow Dozer Blade Agri-Fab Lawn Sweep |
#26
Great build! A real snow killer!
149, 2072, Original, 1772, 1782, #1 cart, Parker 48" sweeper, |
#27
By the way Ken, nice job on the blower.
#28
Moved the filter to the other side.
#29
I liked where it was before, now it looks like a toe ready to be stubbed.
Up to 534 and counting... I give up updating my profile! |
#30
