Old 10-29-2017, 12:07 PM
One issue at a time...
(A) Is the Solenoid wired correctly...??
(B) Did you perform the test as I outlined...??
Old 10-29-2017, 12:09 PM
CMJAnew CMJAnew is offline
AS A TEST.....Run a Jumper Wire from the Large Battery Terminal on the Solenoid to the small terminal where the Blue Wire should be. Tell us what happens...!!!
With the key in the OFF position as well as in the RUN position I got the click from the solenoid. Ran out of hands so I did not try START position (should I?)
Old 10-29-2017, 12:12 PM
THIRD TIME.....
Check and do the things I previously asked. FORGET the Key switch for now.
Old 10-29-2017, 12:27 PM
THIRD TIME.....
As to the wiring diagram _ There is no blue wire (that aside, the wiring looks like the diagram provided) and the fuse wire is connected to the same post as the cable from the battery. (does it matter which post on the solenoid is 'in from battery' and 'out to starter'?
The jumper test provide the same clicking as when I attempt to start the tractor.
Old 10-29-2017, 12:34 PM
The Solenoid "Has To Be" grounded. There needs to be a good ground connection between the Solenoid case (or housing) to the Battery negative terminal.
AS A TEST.....run a jumper wire from the negative ( - ) battery terminal and touch the solenoid (metal part) case. Tell us what happens..!!
Old 10-29-2017, 01:05 PM
Nothing at all.
Old 10-29-2017, 01:08 PM
(A) Is this a genuine Cub Cadet Starter Solenoid..??
(B) I am just asking....Do you have a VOM or DVM and know how to use it..??
Old 10-29-2017, 01:11 PM
Neither the starter nor the solenoid are genuine Cub.
I do have a volt meter - but am not fluent.
Old 10-29-2017, 01:58 PM
What is the Brand Name and Part Number of the Solenoid..???
Old 10-29-2017, 03:21 PM
7935 AMC MTD, Ward, Yard Man, Starter Solenoid; 725-1426, 925-1426, 725-0771, 925-0771 (ItemNumber 30939379997162)
