#21
I go 25 then go over them again at 30 then run it and retorque to 30 once cool.
#23
Maybe #15 first sequence, then go to maybe #25 and the 3rd step arrive @ recommended torque. Then run it till it is good and warm--operating temp-- maybe 10 minutes or better if you cut some grass. then stop, turn it off and let it cool, have lunch/dinner and retorque to recommended torque. Better if you can come back the next day for the final re torque, but if you can hold your hand on the head, it is cool enough to retorque. That should take care of the cylinder head gasket leak. You will observe that the bolts have loosened after it cools down, that is why they need re torquing.
#24
Good analogy though...and I don't mean to nitpick though it probably came across that way. It's just that you gave me a chance to talk about something that I finally know aLOT about. LOL I appreciate the thought and totally agree. It'll be interesting to see if the new gasket is metal like my old one. |
#25
Post removed.
#27
The manual DOES state to run the engine and retorque it. I posted that info just below George's post.
#28
start tightening the bolts following the sequence in the book. the first bolt gets torqued to Approx #15, stop. Go to bolt #2 torque to apprxo #15, stop. Go to bolt #3 torque to approx #15, stop. do you follow the procedure here? If so, when the last bolt is torqued to approx #15. stop. Now they are all evenly torqued to approx #15 NOW: Go back to bolt #1 and torque it to approx #25, stop. Go to bolt #2 and torque it to approx #25, stop. Go to bolt #3 and torque it to approx #25, stop. Go to bolt #4, -- etc, etc. until all are torqued to #25 evenly, stop. Now: go back to #1 bolt and torque it to the given torque listed in the service manual,---- is it #30? whatever it is, go to that torque and stop. Go to #2 bolt and do the same thing,continuing through all the bolts till all are torqued at the final torque. Then follow the starting/ running/heating procedure I mentioned, and retorque one last time assuring all the bolts are at the correct listed torque in the manual. You are tightening the bolts in steps, so as to not warp or break the head, and insure the head gasket is compressed as equally as possible, to prevent leakage. Most all engines do this procedure. Clear as mud? ![]() EDIT: My old book says #25-#30 so I'd go to #30 on the 3rd step. And again tighten to #30 after the running/heating cycle. |
#29
Make sure the engine is cold before re-torquing.
#30
Post removed.
