#21
#22
Hey, I'll fix the one I have if at all possible.
nra1ifer ![]() Cub Cadet 123, Wheel Horse C160, Craftsman PGT9000, Speedex 1631 |
#23
So are mine after I rebuild them....
What are you waiting for? Easy peezy. |
#24
This Cub fan would certainly appreciate your insight on what I might need to do to fix that wobbly throttle shaft. Do you have any specifics on the bushing I would need? I bet I could figure it out, but any time you could save me would help get my 123 back in the garden where it belongs!
#25
I think I found what I needed with a simple search: "throttle shaft bushing hillman"
Some awesome, detailed info! Thank you!
#26
![]() Quote:
I was going to point you towards that..... but I figured since you have been a member since 2010, you'd know where the tech section was.... guess not. Glad you found it. |
#27
Here is the coil I got from TSC to put on my 123:
https://www.tractorsupply.com/tsc/pr...coil-396547r93 Also got one of these: https://www.tractorsupply.com/tsc/pr...actors-2301046 I have thrust washers for the throttle shaft coming from Fastenal. Not easy to find those little buggers in stock here. Took the carb off today. It had a threaded throttle shaft bushing in it, flush with the top of the hole in the carb...... stock? Was able to drill it out and unscrew it out of the hole. Most of it was intact, so I ground off a bit of the top, to make room for a couple of those new washers. We'll see how it all goes together when the washers come in. I guess if it's too much of a hassle, I'll just order a new carb.
#28
![]() Quote:
Napa Solenoid: https://www.napaonline.com/en/p/ECHST76 |
#29
![]() Quote:
For that matter, I have a glow plug relay for my PowerStroke on the shelf that probably would have worked.
#30
![]() Quote:
No, that is not stock. Quote:
