Old 02-06-2017, 10:07 PM
tinkerman tinkerman is offline
Thanks guys, I'll look for the bushing, if I don't find I'll use a bearing. As for the clutch, thanks for confirming it's shot!! Still trying to figure how to get the driveshaft off
Old 02-07-2017, 01:34 AM
Berwil's Avatar
Berwil Berwil is offline
As far as the steering box gasket, you can use sill plate foam and cut your own gasket. I think the gasket is necessary vs silicone because it acts as a spring to hold the thin ring tight to the plate to seal out dirt. I have used the bearing in the top of the steering column before and will do it again, very smooth steering.
Bill
Old 02-07-2017, 06:35 AM
You can leave the drive shaft in and change the clutch in the tractor. Hook the release lever linkage back up to the pedal. Support the drive shaft under neath with a block of wood and lock the clutch pedal down. Pound out the pin that's on the end of the driveshaft closest to where the engine is and slide the clutch components off that way to replace.
Other option is to roll the rear end and drive shaft assembly out the back and then support it while you beat the pin out of the coupler on the rear. The key is to support the area you are trying to get the pin out of so you don't damage a bearing or bend anything. The pins can be stubborn but using some penetrating oil and a good set of roll pin punches and some patience will get it out. And I'm sure you won't do this but please don't be tempted to cut a hole in the the tunnel cover to beat the rear pin out. Hope this helps
Old 02-07-2017, 01:29 PM
The tractor is totally disassembled and I've got the front end raised up with a come along, so access isn't too much a problem. I'm probably gonna separate the front and rear from the frame in order to paint everything. With that being said I'm gonna pick up a pin punch and use instead of the finish nail set tool I used last nite and try again. Thanks for the replys, don't give up on me. Probably be a few days before I get a chance to try again. Lots of busy
Old 02-08-2017, 09:49 PM
Got the pin out. Pressure plates need resurfacing for sure. Throw out bearing shot. The teaser spring isn't broke. If you look at the pics there is tension on the pin in front of the teaser spring.do I just knock it out anyway? Then I'm gonna have to compress the main spring to remove the 2nd pin and get the throw out bearing out? Also the machine shop called today, they got the block bored at .10 over , which is good news. They've gotta grind the crank and install the new valves. Hope to have it back Friday. Now back to the clutch. I don't think that vertical plate that the driveshaft protrudes thru, (saw pic on another post) was ever on the tractor, gonna look and see if it in the parts pile. But I remember when my son and I were fooling with it in the beginning, I told him that it probably needed a clutch. All that was there was the "fork" hanging there, but we drove the tractor like that. I'll check for part and repost.
Old 02-08-2017, 09:51 PM
Ok looking at my own picture what I'm calling a fork is the vertical piece I saw in another post but it was never attached to the bracket at the top...hmmmmm
Old 02-10-2017, 09:38 PM
Ok I made my own clutch spring compressor, I know it looks a little shady, but it worked. I'll probably do something different to reinstall. Cleaned and primed a few more parts. Engine block still not ready. One of the pressure plates is pitted pretty bad . Are these pressure plates as sensitive as ones on a vehicle? If I need a new one I'll get one. My goal is to have a "like new 102" when I'm finished. Can't wait to get all my parts and pieces. (And stop finding things needing replaced) but so far it's been an enjoyable task. Already looking on CL for another. I am going to need a deck and mule cage, so if I can get a whole tractor with a deck, it'll give me an excuse to do another. We'll see how this one goes. Does anyone have a place to buy urethane enamel at a decent price? Sherwin Williams quoted $418 for 2 qts yellow and one white with reducer and hardener, seems kinda steep.
Old 02-11-2017, 03:34 PM
IMO wouldn't a bearing in place of a bushing work better? I've never torn into a steering box but wouldn't it make it steer better/smoother?
Old 02-11-2017, 05:22 PM
Terry C's Avatar
Terry C Terry C is offline
Lot of us use CaseIH paint. No mixing and hoping it's right. I use their hardner and reducer too. I can't recall but maybe $70 per gallon.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 02-11-2017, 05:23 PM
Merk Merk is offline
Page 5 of my topic
Family Owned 70: Project Uncle Dick
Has the procedure I used to rebuild the steering.
Project Uncle Dick
Cub Cadet 70
