Old 09-08-2016, 07:50 PM
JLM78 JLM78 is offline
I have 4 169 all of them are on the frame
Old 09-08-2016, 07:52 PM
Ikswodolg Ikswodolg is offline
Inside of tower looks to have been painted. So no "69" in it. Also no holes in frame from where tag would have been.
Old 09-08-2016, 08:19 PM
Here's a question for the 169 owners:
Is the frame tag the same physical size as a rear end tag? Also, do they have the same wording on them? I want to know if it is even possible to remove a frame tag and put it on a rear end.
The rivets in the OP's tag look pretty old, and the tag doesn't look damaged in any way that would suggest it was removed from a frame.
I love abnormalities.
Old 09-08-2016, 09:03 PM
from what I have seen 1974 cub cadets was on the frame
Old 09-08-2016, 09:26 PM
If you wook vewy cwolsy,the wivits have a been flattened on top,even Rosalie the riveter used a special tool.
Big John,tags are the same,hit the backside of the rivet with a chisel on the frame mounted ones,and the tag comes off.The one that was removed from the tranny was damaged fer sure...
Up to 530 and counting...
