#21
It's a testimony to how well made these machines are. I'm using one that I beat on as a high school student. I have a second that was thrashed by a DPO. It didn't take much to get them both running right.
#22
![]() Quote:
But now, the box store machines are just that mowers. And provided your lawn is as nice a a golf course, and you meticulously maintain and clean the deck every time you mow, you might get a few years from one. We all know there won't be any of these around in 60,50,40,30 years.
Gary 1974 1650 50A "budscub" Was my fathers 1969 125 42" 1978 1450 44A dual hydraulics 1984 782 50C dual hydraulics, waiting for vanguard Z-force Cub cadet Zero turn Sears '66 Suburban 10 Sears '66 Suburban 12 2 Breaking plows, 2 disc's, front blade, rear blade, Sickle bar mower, 2 decks 3pt harrow 74 "Green 100 "John" ![]() |
#23
Admittedly you have a good size set of challenges in front of you...but isn't that part of what drives us in restoring the equipment and giving it new life? You'll work your magic and I can't wait for the final reveal.
![]() INTERNATIONAL HARVESTER - We build the machines that work. 1811/682/782/1440/IH #4/IH QA 42" |
#24
Congrats on the 1250! I know the feeling like other QL owners, they just shake, but at full throttle its acceptable. I did the cradle mod and new iso's on my 1200, and it is as good as I can expect it to be on the vibration. I also recently acquired a 1450 in similar condition as your 1250 and there is a lot of work ahead, but it wouldn't be any fun if it were easy, right? TB
#25
jsoluna, Enjoying following along, just my 2 cents..
![]() I think that is the key right there to reducing vibration. Quote:
I think that's your best bet right there. It's hard to tell from the picture, I was just wondering what the diameter on your center drive pulley is, kinda looks like 5" making it a 44, I'm probably wrong. Exactly. That's why it's good for a hydro, not so much for a gear drive. Quote:
Keep us posted! ![]() |
#26
I'm going to disassemble it this weekend. I looked at the Service Manual and it doesn't mention it having two rag joints, just one as the does parts exploded view. Ball bushing should be fixed to the engine side or hydro side of the driveshaft?
#27
There's a bushing mounted in a plate that bolts to the engine and there's a bushing in the coupler at the hydro. Later models had 2 rag joints. Here's the front bushing and plate.
Doug Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift 1250 w/hydraulic lift, lights,weights, spring assist. 50C deck converted to an A with front wheels 44C deck converted to an A with front wheels. QA-36A 42" blade |
#28
Here's the rear bushing.
#29
Another shot...
#30
This was my 1650 when I first got it. One rag joint and a 5/8" cold rolled steel ball bearing in the transmission input yoke as it was a pre 622952 serial number machine. I went back with two rag joints and kept the ball bearing in place. Obviously had to get longer bolts. And I did that without loosening or removing either the engine or the rear end.
