Old 06-20-2016, 01:31 PM
ironman's Avatar
ironman ironman is offline
Originally Posted by CLE-0129 View Post
Well found out one of my problems. The pto is locked up and not disengaging. So now im looking for the parts to rebuild it.
If the tractor has been sitting for any length of time with the PTO engaged the plates may have rusted themselves to the fiber disk. This happens also with the clutches on gear drive tractors. It may be a good idea to look it (the PTO) over good before you start throwing money at it before you need to.
Old 06-20-2016, 02:47 PM
CLE-0129 CLE-0129 is offline
There is a decal/sticker on the undercarriage which shows the level that the mule drive should be set, but your might be missing. As a general rule, the pulleys should be adjusted so that the belt forms a right angle on each pulley.
Thanks. Will look at them tonight to make sure they are in line. Also gonna take apart the pto to see what all is going on with it. Is there any wear items inside the pto that i should go ahead and replace or can i just clean it up and put it back together and run? I know won't be able to tell till i tear it apart but never torn one down before. Have watched video's on it and it doesn't seem to hard.
