Old 05-11-2016, 10:18 PM
JRoberts JRoberts is offline
Isn't the two piece cam with automatic timing advance set at TDC instead of 20 before? That could possibly explain it trying to spark too far in advance.
Old 05-11-2016, 10:47 PM
bocephus1991's Avatar
I never knew this either! Learn something new everyday!
Brian
Old 05-11-2016, 11:05 PM
clint larson's Avatar
clint larson clint larson is offline
The serial number on mine is 101344. Maybe I'll play around with the timing before I do anything else.
"O", 100, 129, 149, 169
Old 05-11-2016, 11:57 PM
Found some good info on one of Brian millers sites and it states to set timing at TDC on the early two piece cam. It then advances to 20 degrees once started.
Old 05-12-2016, 09:05 AM
ironman's Avatar
ironman ironman is offline
Maybe this will help....
Old 05-12-2016, 12:31 PM
The early 100s had a 2 piece cam that help spin the engine. My 100 would only spin the engine a half a turn before the belt would slip or the starter would quit.
Dale I had forgotten all about that. I have not seen it myself, but I was aware of the two piece cam with the timing advance. I think it was you who brought it up before. Nice catch.
Now you done it. That name isn't very popular here...... I suggest you ask questions here, and get info here.. Unfortunately his site is the first to pop up in nearly any Kohler engine search. He must have made friends with a hacker during one of his runs in prison, for his site to have that many hits in a search.
Old 05-12-2016, 05:14 PM
Didn't know of mr millers reputation, just was not finding much info on web about this situation and was finally happy to see some info on it. Anywho, you guys have always steered me straight, I'd be lost without this site, thanks!
Set timing at TDC and really didn't make much difference, got it to start but it still took awhile. Also tried booster on the battery for a little extra but no difference. Thinking about finding a one piece cam with acr and swap them out, probably pull head and de carbon, check everything in there and put on new gasket since I've never had this one off yet.
Old 05-12-2016, 05:41 PM
Merk Merk is offline
Originally Posted by Billy-O View Post
With something like that, even if it exist, I would imagine it being possible that you're trying to start the motor with spark too far advanced. Perhaps there's a different procedure in setting the static timing with a cam designed for spark advance.
Static timing is the best way (only way in my book) to set the points. This will get the engine running. To fine an engine I will use either a timing light or by sound. I have has a few that the hole and the S and SP mark doesn't line up right or the operator is not looking squarely at the mark.
by clint Larson
Your tractor was made in November of 1964.
Project Uncle Dick
Cub Cadet 70
Old 05-12-2016, 05:44 PM
Thanks
Old age and experience is starting to pay off.
My 100 gave me fits until I change the cam.
Project Uncle Dick
Cub Cadet 70
Old 05-12-2016, 08:42 PM
ironman's Avatar
According to some posters in a thread at this Wheel Horse site there is a difference in the valve tappets so you may need more than just the cam.
http://www.wheelhorseforum.com/topic...181-camshafts/
