Old 04-05-2016, 07:56 AM
Steve, get you one of these. I never had one I couldn't pull off with it.
http://shop.advanceautoparts.com/p/p...ntent=25989081
Old 04-05-2016, 11:42 AM
Dirty Steve's Avatar
Thanks for the suggestions. I'll pick up one of those pullers and some higher grade bolts and give them a try tonight after work.
Old 04-05-2016, 07:51 PM
$13.99 and a trip to Harbor Freight yielded a puller. 3 minutes later- fly wheel popped loose. Ended up with the impact on it. Thought for sure the puller would break. ALOT of pressure was exerted. Now more clean up.
Old 04-05-2016, 08:34 PM
Well done Grass Hopper!
Edit: The rear seal looks OK to me.
Old 04-05-2016, 08:43 PM
looks like a leaker to me.I would remove the stator,then the shroud,then the starter,BTDT
Old 04-05-2016, 09:31 PM
As Lew said. Stator, shroud, and starter off. Degreased for about an hour. What is the best way to clean up the stator?
Old 04-05-2016, 10:00 PM
Blow off with compressed air,
Gaden's Avatar
Gaden Gaden is offline
Do not use solvent, it will destroy the coating (insulation) on the winding's. Water worked for me, if not, some soap.
Old 04-06-2016, 12:15 AM
Yeah I used a bucket of water and Simple Green, then blew it off with the air compressor. Came out like brand new.
Old 04-06-2016, 08:54 AM
Can anyone suggest a time proven way to decarbonizing engine block, head, and valves? And thanks for the tips on cleaning the stator!
