Old 02-15-2016, 03:02 PM
23X10.50X12's should have an 8.5" wheel.
23X8.50X12's should have a 7" wheel.
http://www.onlycubcadets.net/forum/showthread.php?t=477
Deestones do have a tendency to be small, it wouldn't surprise me a bit to find out that they are 2" short.
Old 02-15-2016, 03:12 PM
I had a brand new pair of deestones and a brand new pair of Carlisle's and the difference when side by side was about an 1/8".
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 02-15-2016, 03:37 PM
Jeff122's Avatar
Jeff122 Jeff122 is offline
My only experience with ag tires are the Deestones. I bought them more for looks than anything else. That's when I bought the tri-ribs for the front. Now I want a more aggressive, less rounded lug for plowing. (moldboard) I can only hope the Carlisles are closer to 23".
Old 02-15-2016, 03:56 PM
With a radial tire, you can deflate and gain traction. Not so much with a bias ply. You just end up wearing the sidewalls out. Tried it on a set of Carlisle Lugs. 20psi is about right.
Old 02-15-2016, 04:01 PM
Jeff122's Avatar
Thanks Jonathan
Old 02-15-2016, 04:02 PM
kuleinc's Avatar
kuleinc kuleinc is offline
I been running running around with 6 psi in my other tractors tires, 20 was just so darn bouncy... But the cub weighs twice as much! I aired em up to 20 to set the bead anyways
Check out our videos and our instagram!
1967 Cub Cadet 123 and 122 | 1987 Vanagon Westy with 1.8T engine | 1986 John Deere 330 | 2007 Yamaha Grizzly 450 | 2007 Yamaha Wolverine 450 | 1996 Yamaha Blaster | 1988 Kawasaki JS440 | 1991 Yamaha Super Jet | 2006 Kawasaki STX-15F
Old 02-15-2016, 04:37 PM
sawdustdad's Avatar
All of my 10.50 tires are on 8.5 inch rims. Here is a pair of tru powers (10.50-23-12's) on 8.5 inch rims. Tread is pretty flat. I think they are at about 12psi which I think is correct.
Old 02-15-2016, 04:43 PM
kuleinc's Avatar
I agree not bulgy at all
I may not have 20 in them, I may have 15.... can't remember right now TBH..... but I also should throw in a disclaimer. Some of my tires are loaded, and I run wheel weights when needed. If it's bouncy, I slow down.
Old 02-15-2016, 04:47 PM
kuleinc's Avatar
Sometimes I have to drive on pavement full speed... It gets bouncy lol. I'm gonna try em at full fill 20 psi and adjust from there. Depending on traction I may get wheel weights. Want to see how she does with out first...
