Old 01-28-2016, 07:39 PM
krhoover krhoover is offline
twonton, I see it in your pic, how much movement should I see?
Old 01-28-2016, 07:44 PM
twoton twoton is offline
krhoover, can't say exactly, I don't know the lift on that cam lobe but I'd say in the 1/4" range. Hopefully some with more knowledge will chime in...
Old 01-28-2016, 07:48 PM
Thanks again, going to push or pull in to the garage one way or the other with the old one with the Danco loader on it this weekend. It's the only one running!
Old 01-28-2016, 08:35 PM
Good luck. Keep us posted.
Old 01-29-2016, 05:52 AM
Any body?....
Old 01-29-2016, 08:55 PM
bocephus1991's Avatar
Couple questions. When starting it during the summer, did you have to choke it? Was it using and oil? If so how much? Have you ever rebuilt the carb?
Brian
Old 01-29-2016, 09:05 PM
Any body?....
Not me. OP doesn't seem to listen to "someone with more knowledge", so I'm out.
Old 01-31-2016, 08:02 AM
Sorry about starting anything, I'll get it fiqured out. Thanks to all for all the help and info.
Old 01-31-2016, 09:21 AM
Cam lift is .324 IIRC.
Old 01-31-2016, 01:41 PM
bocephus1990, yes but it started right away. Had head off, valves working ok, Did find a problem with the carb throttle rod being worn at the top and bottom, had a ton of slop. Replaced that, still same issues.
