Old 12-05-2015, 02:04 PM
CSXengr's Avatar
CSXengr CSXengr is offline
Welcome. I have a 129 and use it all the time mowing! And you are right, there is nothing made like a cub! Where are you in NC? There are a number of Tarheels on the site.
CSXengr
_______________________________
124 w hydro lift, 124 creeper gear, 125,126,128, 129,147 electric lift, 149 w/tiller, 1200, 1450 dual 1650 w/tiller control hydro, #2 Cart, Haban sickle mower, Gannon, 17 cubic inch cart.
Old 12-05-2015, 04:00 PM
JLM78 JLM78 is offline
looks worth restoring to me especially for what you paid for it. to put the tires back on the wheels you can jack it up and put a ratchet strap around the center of the tire which should spread the bead to touch the rim and then just add air, put a little soap on the bead to help it seat. id like to point out the 16hp air cleaner and i wonder if you hit the jack pot and someone dropped in a 16hp at some point in its life.
I don't thank its a 169 engine the dip stick would be under The air cleaner
Old 12-05-2015, 06:29 PM
KenInNC KenInNC is offline
Well all the good advice gave us a great success and moving the lawn tractor. One of the Rims was quite rusty and you can see where the previous owner had put sealant around the bead to keep the air from leaking out probably with no success. After a bunch of squeezing and banging we got the bees to see them both wheels. The rusty one still leaked and I ended up putting some slime in it as a temporary hold because it lost air very fast.
I was quite surprised to see the bolt that help the wheel on having a safety wire hole drilled through it. Is that something that supposed to have a wire to keep it from backing out? Kind of like the old security bolts that kept the nuts from backing out?
As far as the Hydro release lever goes it was broken and I could see where the original owner had braised it several times and it still rusted and snapped in two. I ended up using PB on every nut and bolt that I could see and I also put it on the hydraulic pressure relief valves.
So after airing up the tires dropping the deck and sleigh The unit rolled off the trailer with no problem. Hopefully tomorrow will be a new day and inasmuch as I'm busy with other work I'm a little anxious to see if the motor might turn over.
I must admit when I originally saw the tractor with keys in it I was quite happy but then I pulled them out and noticed they were Fulton keys so maybe somewhere down the line it had a ignition switch change.
