Old 09-21-2015, 07:24 AM
Originally Posted by 64fleetside View Post
Shop smells like gas this AM, no puddles underneath, cranked right up. Lights wont come on but all work with a jumper wire. Still cant believe the hydro is clean and dry underneath, even the release valves are dry.
Carb has half throttle to wide open, dies at idle. I'll look at engine mounts at the parts store I used to run, I'm thinkin of trying bird legs mounts rubbers Chevy used in the late 50s early 60s n the front of V8s, they are softer than the Moog sway bar rubbers.
I really didn't have the $$$ to spend for this right now, prop taxes are due 10th next month and need a tank of propane for the shop heater, but had to have a 1650 that was Lew priced and 5 miles away.
On the iso's,
Chebbie quit using them in '57 and IIRR they are bigger diameter, and stiffer.
Try these, posta be soft and supple from what I hear.
Epay# 250639764475.
worth a try @ $20 shipped.
Gas smell:
the needle is prolly weeping, those big bore vibrators tend to beat the needle point up, prolly a needle/seat will be suffice, along with cleaning the carb.
Old 09-21-2015, 06:35 PM
twoton twoton is offline
Hey Brian, How's the gas tank on that thing? I bought 3 Quietlines and 2 had leaking tanks. Leaked real slow, couldn't find it at first but always smelled like gas. One leaked along the seam and had a failed fixed by the PO with what looked like Seals All and the other leaked from where the strap had cut into the tank. I added strips of EPDM rubber as cushions under the straps of the good tank and am still trying to formulate a plan to fix the other 2.
Old 09-21-2015, 09:21 PM
David the tank looks good at first look, gas drips straight outta the carb like my 129 when I first got it. I'll add some rubber once I pull it to check some electrical stuff. Cant get my hands in there to check for power.
George I was also considering those, I have read good things about them, might go solid from Jeff also.
Still didn't get to the head tonight.
Old 09-21-2015, 10:03 PM
bocephus1991's Avatar
Wonder if red kote or epoxy would fix a leaky plastic tank . Anyhoo good luck on rebuilding the carb. Their not that hard to do.
Brian
Old 09-21-2015, 10:59 PM
mobermiller's Avatar
mobermiller mobermiller is offline
hydro lift works fine no side covers though
Hello 64fleetside or anyone who knows. I have a 1650 that I am going to add dual hydraulics to. I have a dual output valve and will be replacing the single output valve with the dual valve.
I'm trying to duplicate the dual 1650 hydraulic control handles. I have studied the parts diagrams of the single and the dual hydraulic setups. The current handle I have is the same handle that is used in the dual hydraulics for one of the two outputs.
The attached photo is of how my handle goes into the Pedestal Assy. It looks like it has a bushing around it. My question is with the dual handle does the sleeve of the 2nd handle take up the space where my bushing is now?
Any photos would be greatly appreciated.
1961 4 digit serial #9643 Original Custom Restoration
1976 1650 dual stick
1989 2072 374 Haban Deck
2001 3240 60" Deck
2A Tiller
Old 09-21-2015, 11:26 PM
You can look on parts tree, should be a parts diagram on there.
Brian
Old 09-22-2015, 11:05 PM
None of the head bolts were 1/4 turn past finger tight. Gasket showed leakage nearly halfway around. Bad connection fixed got lights and PTO working, hour meter still dead. Iso mounts look and feel tight, just bolts missing from cradle to engine.
Old 09-22-2015, 11:10 PM
Here is pic of the levers as they go in the tower, and one inside
Old 09-23-2015, 09:07 AM
Thank you so much for the photos. My questions are answered!
2001 3240 60" Deck
2A Tiller
Old 09-23-2015, 10:31 PM
Took the aluminum muffler box bracket to get TIG'ed up, any alternative ideas for a muffler that is not a stack nor costs a C-note plus? May try to build one even, I thinking a modified 12x muffler, they cost $30.
