Old 07-20-2015, 07:50 PM
AS A TEST.............
Take a long wire. Run it from the Positive (+) Battery Terminal and touch the the small terminal on the Starter Solenoid. Does the starter engage and roll the engine over......????
Old 07-20-2015, 08:01 PM
pdlloyd975 pdlloyd975 is offline
i know it sounds weird, but i KNOW i've started this thing IN gear before.. many times.. so i don't think there is a switch on the brake / clutch... HOWEVER, after having it on battery charger for a bit, i noticed that the black wire (shown in the pic) to the coil was VERY hot.. so i disconnected... Thoughts?
I'll do the "test" from battery to the small term on the solenoid now.. standby for results.
Patrick
75 & 76 Cub 1200's
44" decks & front blade
Original Service Manuals
Old 07-20-2015, 08:10 PM
Roland, it did not turn engine... When i started project "get dad's tractor running again" i could take hot side of battery charger, touch starter, and it would turn over...
Patrick
75 & 76 Cub 1200's
Old 07-20-2015, 08:15 PM
i hear ya... but as some history... i took the one off the 76 (which runs) and swapped it with the 75 (current project)... 75 wouldn't hit a lick and 76 still started (with 75 solenoid) THEN, while "messing around w/wires" i think i did blow it up.. so i replaced the solenoid..just put on this eve.. Guess it's possible that it's bad, but not likely right? I'll get another tomorrow and try it.
Patrick
75 & 76 Cub 1200's
Old 07-20-2015, 08:16 PM
actually, i've swapped the following from the 76 to the 75 to no avail...
solenoid, ignition switch, pto switch, coil, plug, plug wires...
Patrick
75 & 76 Cub 1200's
Old 07-20-2015, 09:13 PM
Thanks.. ran outta daylight... i'll get back on it again tomorrow evening.. I'll try the VOM first and report back... Thanks everyone! (it's easy to lose your sanity on a project like this!)
Patrick
75 & 76 Cub 1200's
Old 07-20-2015, 09:17 PM
I've read and seen that you have made new ground cables/wires but have you checked the actual ground cable from the battery to the frame?
Old 07-20-2015, 09:33 PM
Billy-O's Avatar
Billy-O Billy-O is offline
As you follow Roland's advice using the long wire from positive battery to small terminal of starter solenoid, your test light should light up if you touch the positive terminal on the starter.......does this happen?
Plow blade
#2 Cart
QA36 snowthower
Old 07-21-2015, 12:42 AM
bocephus1991's Avatar
That black wire runs to the points. Will crank even if it's not attached. That's one oily coil! Your starter isn't locked is it? Or bendex half way out? Mines done that. A little wd 40 and a screw driver fixed that on mine.
Brian
Old 07-21-2015, 04:54 AM
No one has asked.....
You said this tractor has set for 4 years.... Will the motor turn by hand???
