Old 06-09-2015, 07:38 PM
Sam Mac Sam Mac is online now
You can resurface it yourself.
Here's how I do it. A piece of plywood to secure the 600 grit emery (sand ) paper, a stapler and some water.
Use a circular pattern and check often to make sure you are pressing evenly.
Jeff
You know I agree with you almost all the time but I have to disagree with use of plywood to resurface a head. I use a piece of 3/8" thick glass under the wet dry sand paper, plywood is just to irregular to get a good flat surface.
Old 06-09-2015, 08:04 PM
timbo2's Avatar
timbo2 timbo2 is offline
I like the glass under it too. I haven't used such a fine(600gr) sandpaper though, will try that.
- Tim
Old 06-10-2015, 10:01 AM
Bob95065 Bob95065 is offline
I hung on to a cutoff when i put granite counters in my house. It's ground flat and works great for lapping heads.
Old 06-10-2015, 08:26 PM
Jeff
My picture shows the glass window pane but I forgot to mention ( write ) it. I did edit my wording last night to include "window pane".
It is corrected now
Old 06-10-2015, 08:59 PM
Rmowl's Avatar
Rmowl Rmowl is offline
Definitely used glass in the process. Back down in appomatox va but will run the 102 again some more this wknd. I was up in your neck of the woods last week in Lehigh valley, bushkill pa. Tore some brookies up on toms creek in the evenings, nice benefit of working up north. Anyways, I'm confident the repair is solid. Thanks
-Rick
IH 782
IH 126
CCC 1863
Old 06-10-2015, 09:48 PM
Roy Najecki's Avatar
Roy Najecki Roy Najecki is offline
When installing the head bolts, should anti-seize be applied to them? If yes does that affect the torque setting?
Old 06-10-2015, 09:53 PM
timbo2's Avatar
I just dip them in a little motor oil. I think thats what the manual says.
- Tim
Old 06-10-2015, 10:45 PM
BassBlaster BassBlaster is offline
You should always replace the bolts and studs when you remove the head. The fasteners have been through heat cycles and loose their tensile strength.
Per the instructions that came with my head gasket set from Kohler, they said it isn't necessary to use new bolts and they don't include new bolts with the gasket kits anymore. This was a CH engine.
1994 Cub Cadet 1864
1997 Cub Cadet 2165
Old 06-10-2015, 11:56 PM
Merk Merk is offline
The engine in question at the beginning of this topic was a K series engine. As I stated earlier it is cheap insurance regardless what the instructions that came with your head gaskets kit.
Project Uncle Dick
Cub Cadet 70
Old 06-11-2015, 03:19 PM
sawdustdad's Avatar
OK, one more item not mentioned--chase the head bolt hole threads with a tap and clean out the debris before replacing the bolts/studs.
