Old 06-08-2022, 05:13 PM
CubDieselFan's Avatar
Originally Posted by ohioguy View Post
I have the same issue on my 2284. Based on the explanation of the cause what would the direct solution be, finding the cause of the voltage drop?
I could use the pictures also, I like the solution!
That is a possibility but my 1864 shipped from the factory with this mod.
Old 03-03-2025, 11:43 AM
Rex B Rex B is offline
Someone recently posted a ebay venor selling a 5-pack of relays, complete with a plug and harness, all for $10. I bought the pack and this week finally installed it on my 2084. Instant satisfaction. Now I don't have to keep my engine running all day. 1864 is next.
Old 06-21-2025, 02:03 PM
Uncle Paul Uncle Paul is offline
This is fantastic, and almost certainly what’s been ailing me..
Question though. I don’t seem able to see the pictures that are mentioned.
The references to connectors 86, 87, and 30 aren’t clear to me.
“Remove the blue wire from your solenoid and connect it to the 86 connector on the relay. 2 down, 2 to go.
Run a wire (I used green) from 87 to the connector on the solenoid you just removed. 1 more to go.
Now run a FUSED wire from 30 to a constant 12v. I used the included 15 amp fuse.“
Any insight is enormously appreciated!
-Paul
Old 06-22-2025, 12:36 AM
SS5150's Avatar
SS5150 SS5150 is offline
Paul reference post #14 in the thread. And substitute the word 'terminal' for 'connector', and it should make more sense.
86, 87, 30, etc are terminal locations on the relay. When you have a relay in your hand it should make more sense.
RUN IN THE RED
782 w/50c deck (red); 782 dual stick, 44c deck (y/w);
1050 w/38c deck; 1864 w/54" GT deck;
1872 project
Cub Cadet Pro Z 560 L
42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper
1200, 1863, 1864 parts machines
Old 06-22-2025, 12:17 PM
Thanks so much SS!
Old 06-22-2025, 12:27 PM
ironman's Avatar
ironman ironman is offline
In case you weren't aware and are going to purchase a relay,
they are available with a built in fuse holder.
Old 06-26-2025, 06:19 PM
Thanks Ironman!
Old 07-02-2025, 07:41 AM
jsoluna's Avatar
jsoluna jsoluna is offline
Just wanted to mention that we sell a plug and play kit for this problem, both for the Kohler Command and for the Kubota Gas/Diesel engines. For those of you who don't enjoy wiring:
https://solunagarage.com/shop
http://www.solunagarage.com
