Old 04-13-2015, 04:06 PM
Cannon51's Avatar
Cannon51 Cannon51 is offline
The bearings arrived today from VBX http://www.ebay.com/itm/400317498031...%3AMEBIDX%3AIT I cleaned up the spindle housings and parts and drove the races in. I packed the bearings and put them, the center spacer and the seals in. I turned the bottom seal out, hope it doesn't get torn up.
I didn't expect Timken bearings but was surprised that the numbers are not the same. I trust that VBX knows more about bearings than I do. Still haven't started on the deck shell. The bearing and cone are both marked 78049.
Cannon
Old 04-13-2015, 04:16 PM
Give them a call to check that what you got will interchange before you install.
Old 04-13-2015, 06:56 PM
I believe he posted he installed them, prolly just selling them as a set.
If they were not right I think he would know it, as they would not fit.
They are not top of the line, but for the price I don't think a fellow could go too
far wrong.
Kept lubed, they will prolly outlast the deck.
Old 04-13-2015, 08:06 PM
Cannon51's Avatar
They are installed, the races went in about as tight as the old ones that came out. Bearings are a slip fit on the shafts. I did send an email through ebay asking if they were the same. I was just looking at old Cub Cadet spindles on ebay, $$$
Cannon
Old 04-14-2015, 03:51 PM
Cannon51's Avatar
I sent this message.
Dear irvineman,
The bearings I received were not numbered as expected. The item was supposed to be a bearing and race LM11949/LM11910. The bearings I received were marked 78049 (made in Russia) on both the race and bearing. Are these bearings a direct replacement for the LM numbered bearings.
Thanks
Received this reply today.
We do apologize. We are sending out another package right away.
Regards,
Diane
- irvineman
I thought they would say they were the same. I guess I need to knock the others out.
Cannon
Old 04-14-2015, 05:44 PM
Dear irvineman,
Thanks
Regards,
Diane
- irvineman
Cannon
I would wait till you get the second shipment, might be the same bearings.
and if the bearings you put in there are tight, and fit correctly, use them.
And save the second shipment for the future.
Old 04-14-2015, 07:53 PM
X2 on what George said plus you stand the chance of damaging them when you remove them along with the possibility of damaging the housings. If they fit I'd run them. Put the extras in a zip lock bag after you oil or grease them and put them away.
Old 04-14-2015, 08:31 PM
Cannon51's Avatar
Well I do have another 317 deck.
Cannon
Old 04-15-2015, 07:28 AM
Well there you go, spare parts for free is always a good thing.
Old 04-15-2015, 09:49 AM
I would use them and keep the other set for future use. Here is what my cheap a$$ got but I haven't used them yet. Has anyone tried these yet?
http://www.ebay.com/itm/281469436514...%3AMEBIDX%3AIT
