#21
Thanks for the heads up guys....I will have to do some investigating this week when its nice and sunny out so I can see what the exhast is like....might have to try this a couple times and break out the manual!!:biggrin2.gif:
#22
Gum Out....carb. and choke cleaner works well. was all i used when re-building my Carter carb. on my 71.
#23
Before you try to set the carb... make sure the timing is spot on. I spent several hours trying to set the carb right on my 1650... and all I needed was to set the timing. Just pointing that out...
Tyler Chiliak. Southeast Alberta Canada. My dad and I own, 1650, , 1450, 1250, 1250, 1200, 982, 782, 149, 149, 149, 128, 128, 123, 100, 100. Also a 1310, 1500, and 2 1600 IHC trucks. |
#24
Improper timing isn't going to make the exhaust smell like raw gas.
#25
Well, I used the 982 for about 2 hours steady tonight with very little problems. I am thinking it is just finally getting itself straightened out. I turned it off 3 times in that 2 hours and when I fired it up each time, no smoke...smelt raw fuel once in the 2 hours. Everything was fine with it...no hesitation, idled good, lots of power (mind you I was only pulling an spring tine areator) but up and down hills no problems. I think it just needs to be worked a bit. The guy I bought it from didn't have a very big lot and I don't think he owned it long either, so it didn't get a lot of use - but I am just speculating that!
#26
Also just keep in mind that these older L-head engines aren't as efficient or as clean-burning as the newer V-twins and are going to smell a bit.
#27
awesome sound advice! thanks for sharing.......going to have a closer look at this!
