Old 02-06-2015, 07:32 AM
This one is going to be cool from the looks of it. I have the same spring but I had Mid West set it up at a lower compressed length so it's no harder to push the clutch down than a stocker. You can just back the lock collar off a little if you find it's to much. We went with a 5" compressed length.
Old 02-06-2015, 08:57 PM
homebuilt homebuilt is offline
clutch reinforcement is already in place.
the hood clears, the battery clears, still working on the fuel tank. thanks on the heads up about backing the spring off.
Old 02-07-2015, 01:22 AM
cubby102's Avatar
cubby102 cubby102 is offline
Im liking this so far! Makes me wanna do a vangaurd for my plow project
Old 02-07-2015, 09:56 AM
snoel's Avatar
snoel snoel is offline
I like what you're doing.
Key to "tipping" issue, is "rear" width, height and rear weight.
What is the green front axles from?
I also like the flat top fenders.
Really looking forward to the finished project.
Steve
Old 02-07-2015, 09:59 AM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
You're making some good progress and giving me ideas! Keep the pics coming.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 02-07-2015, 10:03 PM
the green front axle is a rear axle tube off a john deere, nit my idea. I believe sam mac posted a link to it earlier in this thread. I didn't get much done today. between work, the wife, and two kids the shack time has been slow. I did get the rear tires on the rims and some parts fitted up for measurements.
Old 02-08-2015, 07:33 AM
I didn't post a link for the axle tube you used. I do recall seeing someone else that used a setup like that. Maybe Zippy or 4speed?
Old 02-08-2015, 07:48 AM
you might want to check post #11, the third link that you posted!
Old 02-08-2015, 12:45 PM
I bought mine off epay. But it was made with the same JD rear axle.
You did post a link Sam
Old 02-08-2015, 01:00 PM
See what happens when you get old, the brain goes bad.
