Old 01-06-2015, 09:33 PM
Merk Merk is offline
So what would be an unhealthy reason to run with a smidge of choke? Gotta learn somehow and asking is easier than learning the hard way
The fuel I was running with yesterday was maybe a month old (whenever we got our first snow). Half had sat in the tank and half had sat in a gas can on the garage floor. When I got done today, I topped off with with fresh from the gas station gas. Hmm, didn't think about that
Any fuel a month old is added to my truck.
I have better results with fuel for my small engines if I don't sit it on the floor(cement-gravel-dirt). It seems to draw moisture more than fuel that sits on a piece of wood.
Project Uncle Dick
Cub Cadet 70
Old 01-06-2015, 10:38 PM
jimbob200521's Avatar
I don't like letting fuel sit that long, especially in a machine. But with the lack of snow, all I can do is start it up and let it get warm once every couple weeks. As for the gas in a can, that actually crossed my mind today when I refilled my gallon can. Instead of setting it on the concrete floor, I set it on a 2x12 wood ramp. Here's to hoping I suppose.
-Ryan
Old 01-08-2015, 02:29 PM
Guys, I just wanted to shoot out a quick update. After the 3 hour snow-a-thon that turned into the partial choke to run smooth, I naturally went through a several gallons of gas. So, before I went out yesterday to play some more in the snow, I topped off the tank with fresh from the pump gas. And guess what? I ran just fine with no choke for the hour or so I plowed. Guess it was either a fluke or some moisture in the gas.
-Ryan
Old 01-08-2015, 05:18 PM
Todays gas does not have a very long shelf. Automobile engines can tolerate old gas better because they have more mass (crank-rods-pistons-flywheel) turning and more cylinders to make up the gaps than a single or 2 cylinder engine.
Project Uncle Dick
Cub Cadet 70
Old 01-08-2015, 06:09 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Glad it's running right again, Ryan!!
At 8 cents per gallon to treat, I don't worry about my gas going stale in any less than 2 years. http://www.archoil.com/ar6200-fuel-m...ation-complex/
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
