Old 12-27-2014, 11:36 PM
Originally Posted by BThein View Post
I really hope it is a crossed line someplace like I wrote in an earlier post I have done it myself but right at the pump but hose are right.I don't own pressure gauges good excuse to buy more tools.I do have 2 or three pumps and could switch out a relief valve .I have zero experience inside the hydro unit so I have been studying the parts diagram.
Bob
I wouldn't worry too much about the "guts" of the pump..... they almost never fail. Weak charge pump is about as bad as you can expect.
I didn't miss it Sam, Travis had already pointed it out.
Old 12-28-2014, 07:46 AM
I was just busting you.
Old 12-28-2014, 11:06 AM
PaulS's Avatar
PaulS PaulS is offline
Had the same problem with our 2072. I had good pressure at the pump but had no power steering or lift. After much hair tearing out and a bunch of cleaning on the bottom of the steering shaft to read the connections I found that the input line from the pump (output at the pump) was connected to the out connection on the steering box and the out line was connected to the in connector. We switched the two lines and everything worked as it was supposed to.
Old 12-28-2014, 08:11 PM
BThein's Avatar
BThein BThein is offline
Well I checked the lines running to the front and everything was good but still no power steering or lift .I got looking closer at the hydro and not just the charge pump but the whole unit looked like maybe someone was into it.I had the parts 2072 sitting there and just said ok stop messing around and I swapped it out.I now have a running driving 2072 with power steering and the lift now works fine.At some point I may open that one up and see what was done but for now I'm just happy everything is working.Thanks again to all who took the time to help out.
Bob
Old 12-28-2014, 08:16 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Bob
Glad you got it going Bob! Parts tractors are nice. It usually takes me longer to convince myself to do something, than it does to JUST DO IT!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 12-28-2014, 08:24 PM
Bob
Great news. Glad you got it fixed.
Old 12-29-2014, 04:46 PM
BThein's Avatar
I have one more question ,I have a complete Super hydro pump assembly with a worn input shaft.Would it be tough to swap out just the shaft that way I would have a spare complete rear.I have looked at the parts diagram but thought maybe someone that has done it could chime in.
Thanks , Bob
Old 12-29-2014, 06:20 PM
Pump needs to be dissembled. I guess it depends on what you consider tough. Take a look at the manual and you'll see what's involved.
