#21
Got the nut off. Does the screen ride freely between the engine shroud and aluminum pulley? Driven by the tab on the pulley? It looks like mine has tried to spin at sometime cut a groove in the pulley tab. Also, it has torn some of the screen around the i.d. Do I need to try to fix the screen somehow? Thanks!
#22
There should be 4 little screws holding the screen to the pulley.
I believe they are 6-32. I used loctite during reassembly.
1966__122 Cub Cadet. Owner: Calvin, 6 yrs old Dad: Craig |
#23
That explains everything. I wonder how long mine had been gone and the pulley was driving the screen. I see the tapped holes now in the pulley. They are filled with dirt and crud so the screws have been gone for awhile. Thanks for your help!
#24
Thanks for the help again. Just in case someone in the future reads this post, my pulley was tapped for 8-32's. I definitely will use Lock-tite!
#25
Two questions. Is this engine block clean enough or does it need cleaning some more? Next, I realize now I should not have painted some areas on the control lever bracket and I am going to remove the paint from the pivot areas. Is the C shaped retainer supposed to be driven on the shaft, all the way to line up with the washer underneath? Was mine working its way off when I dissembled? Thanks!
#26
While I was waiting on some rear end gaskets to come in, I kind of got ahead of myself. I flattened the head and installed the head gasket. Torqued to 10,20, 30 per the proper sequence. I'm going to pressure wash the engine, tape off the head,paint the block black and the rest yellow. Now I realize I have to take the head bolts back out to install the top cover and heat shield. I probably should have only torqued to 10 while I was still prepping the engine and then do a final torque when I installed the covers. Should I a) order new head gasket b) torque to a higher number at final assembly, say 32 c) just torque again at 30?
#27
You haven't ran it, so its fine. Use the gasket over. I'd torque to 35. Not because you used the gasket over...... but because after you run it and go back to retorque they should be at 30.
#28
Great! Thanks for the help J-Mech!
#29
I want to give you guys an update and ask your opinion on a couple of points. I've spent the last week fixing little things, trying to get everything together to start putting the 105 back together. Lots of separate issues to work out! Went to TSC last night and got most of the hardware. Buying by the pound is definitely the way to go. I keep reading about Hydro leaks and I want prevent any before I put the rear end back in the frame. Should I put anything on the threaded connectors for the aluminum cooling tube? I think I read somewhere about using teflon tape? Also, I've never painted fiberglass. Does it need any special prep, prime or just topcoat? Thanks for everyone's help! I've attached a few pictures of the work in process. The first two are the questions.
#30
Painting the fiberglass is nothing special, just prime with the correct primer for the topcoat of your choice. Nice work so far! |
