#21
thanks for stopping me from connecting it that way Jonathan-that would have been something to see!!
I will try to post a pic, the terminal on the backside is not labeled at all tho. the 3 on the one side of the NEW vr are "F" "BAT" and "L" MY old VR had 4 wires. one for "ground" (on the back) one "gen" "bat" and "f"
![]() ![]() Cub Cadet 108, IH snowthrower, IH ?? mower deck Cub Cadet 1650, IH 44 mower deck, IH snowthrower 1960 Cub LoBoy- yellow roundnose. Fast hitch w creeper and roto tiller, front blade, mower deck and Fast hitch one bottom plow and rock rake 1951 F Cub with Wagner loader and woods brush hog, 152 disk plow and 23A harrow 1953 Ford Jubilee tractor and F100 Pickup ![]() |
#22
The one on the back is the new "G" terminal. Seen this many times. Do not use the "L" terminal. Base is supposed to be grounded already. I believe it has a strap, either braided or it looks like a small wire. You are the second person today I've helped with the same problem. Other guy was on FB.
#23
thank-you you are very kind.
I will report back when I hook it all up!
#24
![]() Quote:
#25
it charges perfectly! BIG THANKS!
#26
Yeah...... and mainly all I do is watch news feeds about politics (I watch that stuff pretty close) and cub cadets. Don't worry, I push OCC on there as much as I can.
#27
Glad that you got it figured out.Did you get the NAPA one?
#28
I had already ordered one before your post on Amazon for $29 with free shipping. said is was tested before shipped from RareElectrical.
NEW 12 VOLT DELCO AGRICULTURAL GENERATOR VOLTAGE REGULATOR 1118981 1118988 the napa one was around $70. I gambled on cheaper and perhaps won this time will see in long run.
#29
Wow i did not know they were that much!
#30
this thread has a pretty good sequential chain of diagnosis tips. and its got the right title.
so i had a bad voltage regulator and replaced. it charged for maybe 6 months and then stopped. of course i hadn't committed the charging circuit to memory and I had put a cigarette lighter tap at the battery to run a sprayer i towed behind, so i put a cigarette plug on a harbor freight charger and just been running it that way for a couple years, like a plug in hybrid so to speak. just had to tear it down to fix leaking head gasket and got into the while you're there department. so the field wire is showing continuity to ground but i pulled it and made a ground jumper from the field terminal and still no charge. a tiny bit of voltage pops up when i ground the field terminal, 1/4 or 1/3 volt. generic generator testing procedure says check the brushes and polarity although the thing runs perfectly fine as the starter when i engage the solenoid so i'm thinking that can't be the problem. just about to pull the generator and take it to the armature shop but thought i'd crowdsource my logic. thanks, brian |
