#21
Guys, you can't change the direction of a fan by turning it around. Not matter which way a fan blade is installed it will move air the same direction. Now, it does matter which way it is installed, because one way the curve of the blades makes more air flow, while the other way it doesn't move as much air.
Yes, put all the engine mounting bolts in. If you were ever getting fuel in the motor, it wasn't a result of not shutting the fuel off. No matter how you look at it, either the float valve in the carb is faulty, or the fuel pump is bad. Either way, you should fix it. If it is indeed a leaking fuel pump, and you shut the gas off when it's sitting, the fuel pump still leaks when the engine is running. It's very important that no gas gets in your oil. Make sure whatever the issue is, that it gets resolved. |
