Old 05-29-2014, 11:06 PM
Gfann Gfann is offline
Default My 125 is driving me insane.
OK, heres the deal. This might get long but I'm going to try and cut to to the chase.
I have a 125. It did start but chugged slightly before starting. The chugging got worse. I found the condenser wire was broke I replaced it. problem continued. I took carburetor off cleaned it and replaced the gaskets. still chugged. I replaced the coil & plug gapped to .025 and checked points gapped .020 . Still chugged. I replaced the starter, the solenoid, and rebuilt the wire harness [the harness was dried out and cracked in places thought it may have a ground issue]. Still it chugs, however now when I connect the batter it just tries to start without the key. The wiring is correct as far a sI can tell. I ordered a new regulator, but I did try a regulator off my 100 which is the same part number and still it chugged. I recently used a different starter motor because I read a thread with a issue with a wobbly armature that dragged and created a similar problem. But didn't help, still chugs! I don't have a pressure gang but I'm going to pick one up though.
My theory now is it is something with the engine perhaps the valves. or the rings. I did take the head off recently, earlier on in the process to check the valves and head, everything looked good, I did replace the head gasket. the combustion chamber had a .20 stamped in it. I believe that means the block was bored at one point which leads me to believe that issue maybe the engine.
IDK
