Old 05-02-2014, 06:45 AM
Looking forward to your build Ryan! Definitely unique with the chipper mounted on the rear.
I agree.
Old 05-02-2014, 07:29 AM
Big pulley, little pulley. Change them to get the speed right. NBD.
Two things: 1.)That's a lot of weight to be hanging off of 3 3/8" bolts. Might want to make a brace.
2.)If your going to drive it off the rear and you don't use the rear PTO, why not just use a tiller gear box. That way you can use the same belt. Just unbolt the box and turn it 90°. The rear gearbox plate is made so you can do that. The holes are already there. (On the newer style, some of the old gearbox brackets didn't have both sets of holes.)
Rear PTO's on the gear drives run 540 RPM. The ones on the super's run faster...... 1800 I think, but I'd have to look.
Thanks for your input Johnathan. I'm positive that the governed rear PTO speed for the older Cub is 515 RPM according to the service manual. Just too slow to use without some major stepping up. I will be adding braces from the rear of the tractor frame to this frame.
I knew that this frame bolted to the rear end was designed to incorporate a rear gearbox for the tiller. I wanted to find one initially but they are just too expensive for this. I figure I will get this frame a little closer to the tractor so there isnt so much leverage and weight hanging off the three bolts to the rear end. I think two idler pulleys similar to a mule drive right underneath the chipper pulley will work fine. I'm thinking mule drive pulleys from an Original mule drive. They seem to have some girth to them
My hope is that i can get the one longbelt straight and tight enough to run it. But, if it dosent work, I have other options too. Thanks for the input guys!
Old 05-02-2014, 09:27 AM
Berwil's Avatar
Berwil Berwil is offline
Thanks, I'll tuck that nugget away for next time.
Bill
Old 05-02-2014, 12:02 PM
Same here!
Old 05-02-2014, 02:36 PM
red56turbo's Avatar
Ryan,
Neat idea. Can't wait to see if it works for ya.
Rear PTO's on the supers are 2000 RPM at WOT IIRC. I know the rear tillers and such are rated at 2000 RPM's.
Josh
Diesel Cub Cadets...........
Old 05-21-2014, 08:25 AM
Well, I finally made more progress on this project.
After I welded the chipper to the frame, I used a mule drive pulley setup from an old Original I had here for parts. I just used the bolt, idler pulleys and spacers and welded them solid directly underneath the chipper pulley.
Old 05-21-2014, 08:33 AM
After this, I added a front mule drive setup from a narrow frame to the front, and ordered a 1/2" x 176 inch belt to drive it. Nothing special, just a classic A belt. It makes the twists and turns very well. I made sure my PTO was working and I tried it out. WOW! These things are wild, dangerous, and fun!
After the test run, I added my belt shield using some 1/4 inch bolts and some copper spacers I made. I also added the chains to the top of the chipper to avoid it bending down and putting too much stress on the bottom bolts. It is very strong (suprisingly) and probably wouldn't need top braces but I think J-Mech's advice is good so something should be up top to help it out. I already made two #2 cart fulls of mulch with it already so it is working well.
Old 05-21-2014, 08:36 AM
Overall it was a fun project, and very simple to do. I wanted to go through what I did in case there is other guys out there with 59M's that have no mounting brackets and want a creative and "out of the box" idea to mount theirs. If anyone has any questions or comments about the project, please let me know or PM me!
Old 05-21-2014, 10:39 AM
Looks good Ryan! Very neat setup with it on the back!
Old 05-21-2014, 10:51 AM
Vin122's Avatar
Vin122 Vin122 is offline
Awesome! I'm glad to see you got it to work!
