#21
How would you accomplish the trans /tranfer unless you went hydro as the trans is in the trans/axle maybe a hydro frt end only use as needed
most of the mudder vids I see, they are just 2wd LT's getting stuck, which I think is kind of the goal /fun |
#22
I have used welded rears on race cars with great success but it's going to increase your turning radius by a ton even if you only weld up the rear diff. You are likely to break the rear if you plan on a lot of low speed, tight turns. Nothing like a 15-point turn to get out of the paddock onto the starting grid. If you've got plenty of parts to play with I guess it wouldn't hurt to try it.
Current: 102 122 SZ60 Past: Original 71 72 73 86 100 102 122 123 124 125 127 129 147 149 169 383 582 682 782 782D 784 982 1000 1050 1100 1200 1204 1210 1250 1282 1415 1420 1440 1450 1535 1541 1641 1650 1710 1711 1730 1806 1810 1811 1860 1861 1862 1863 1864 1882 3185 3200 3205 7265 |
#23
No help on your future build, but I do agree somewhat with the naysayers and I do have respect for you trying something outside the box.
We've just seen enough "projects" started with many giving their input and not seeing an end to the project. If it is something your set on building come hell or high water then get out your paper and pencil and start the design and gathering up parts and have at it. I wish you luck, and look forward to the end results. ![]()
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! ![]() |
#24
![]() Quote:
As I said before, just gathering ideas and nothing is concrete.
1981 IH Built 782- 44" deck 1650 dual stick 71 "121" round fender and replacement k301 carlisle tru powers and v61 |
#25
I am in the same boat as you are in. I am going to get another MTD I think it is, and make mine a 4x4. I am not going to ruin my 127. I have not the money to get a 4 wheeler and don't need a ton of high speed to just tool around the woods.
Basically, I am going to put larger tires on it, a larger pulley, and some suspension under the front to allow just a bit more pivot. I know its a tractor. That's the best part. One is like an 84 Murray. So if its messed up, who cares. Mod a lawn tractor is like 300 bux in parts. Where can I get anything close to that in a 4 wheeler? SWS |
#26
![]() Quote:
http://www.ebay.com/itm/Complete-198...820858&vxp=mtr http://www.ebay.com/itm/Honda-110-At...2a7aa2&vxp=mtr http://www.ebay.com/itm/Honda-200s-A...2a7e32&vxp=mtr I found four in less than 5 min. Apparently your not looking hard enough. |
#27
Unless you have the skills needed to do the project I agree with the nay sayers. As a learning project it may well be too difficult. On the other hand if you have fabrication skills you need to say so.
Murray Mayhem has been working on his tandem axle murray gator for a while. He originally started with 2 transaxles. I think he gave up on that because he could not make them shift together. He is now using 1 transaxle and driving the 2nd axle with a chain.. His plan is to lock the diff so the transaxle will be driving all 4 wheels all the time. That has me wondering if he will be trashing a lot of transaxles. If I were to go this route I would forget mechanical linkages and shift with small linear actuators. If you go that route I can help you with the control circuit. |
#28
This thread for some reason seems to create an undue amount of controversy. That said if you want to build a 4X4 something go for it. The engineering to make it work properly for a one of a kind machine is a bit much but some of you guys have the talent to pull it off. I do not and I will not try to talk any of you out of doing it. Some of us have tried to convince you that it may be for whatever reason not something that you wish to pursue and have gotten a lot of flack for our comments. So with that said if you want to build a 4X4, have at it and please feel free to share the build with the rest of us. I'm only speaking for myself but I'm willing to bet that the other mods will also agree and will sit back and watch.
![]() Merry Christmas and Happy New Year.
#29
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
#30
Its your time, your money, your project, and if thats what ya want to do just do it and forget about all of the negative crapp you hear along the way.Good luck with it and if and when you start it keep us posted.
