#21
![]() Quote:
#22
It's Okay to have a hydro Sam.
I would think he would want one cause they are faster than gear drives...
#23
![]() Quote:
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! ![]() |
#24
The tractors look good Lew! Yeah, that seat is pretty rough so you better send that 6 pad my way!
#25
![]() Quote:
#26
So the last few days I worked on the 70, after pulling the head off with a bad spark plug thread,I noticed the valves were loose in their guides also,started it up after fixing the head,but man what a knocker,it wouldn't throttle up,just die,changed the coil and the condenser,and the same thing happened,lots of blowby.So I pulled the motor,found a few PO boo boos,he put new valves,but didn't change the guides,prolly didn't matter as he put the rod on incorrectly.
#27
![]() Quote:
That the K161 that's in your other thread? |
#28
That stinks Lew!
#29
![]() Quote:
You got lucky Lew ![]() |
#30
Yes it is, the PO changed the cast iron gov gear to a plastic one and was wobbling around on the shaft.The crank is still good though,but it needs to be .010 under.
Its a keeper ![]()
