#21
I check the oil in all my small engines each time I start them. My 1250 Nightmare uses a very small amount of oil, and I need to add about every month. That isn't bad, but I still check it.
#22
That's what I do because my 1450 and new(to me) 125 burns some oil.
![]() ![]() ![]() ![]() ![]() Grandpa's 1961 "O" w/ mowing deck, 169, 149, 147, 1000, 125 w/creeper and 3pt, 1250 w/ 44A deck, 1650, Frankenstien 1250, Great Grandpas 1968 Cadet 125 w/original QA-36, CCC 1711, Model 2 tiller, QA-42 and a QA-42A Snowthrower, Cozy cab May not be as much as others, but we're still building our fleet! There are more to come! Connor |
#23
None of my cubs use oil . I check the oil evert time I use one just for peace of mind . I did find that the fuel pump had failed on my 682 and filled the crank case with gas one time . Had I not checked the oil then, it would have been a disaster .
#24
Yup, before every start up.
Daniel G. ![]() . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
#25
Before every use, especially on my 682 because of there fuel pump's that seem to go out all the time.
-Ryan
#26
Before every use and every time I add fuel.
My question is; Why wouldn't you?
#27
Every time I go outside with my CC key I check oil, gas and take a quick look over the entire machine.
The first Mrs. cubby wouldn't check oil on a car until the oil light stayed on at freeway speeds ![]() ![]() |
#28
[QUOTE=Yosemite Sam;
My question is; Why wouldn't you?[/QUOTE] Great point.
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! ![]() |
#29
I always check the engine crankcase oil in the 71 before start up, and the fuel. After the tractor shuts back down, I check the engine crankcase oil once more, and top off the 5 quart fuel tank if needed.
On another note, after the lunch break, or waiting on a load of material, ect. , we always gave it thought to check the engine oil in our construction equipment. There was more than one time, where I caught a problem developing whether it be low engine oil, engine oil contamination,.
IH CUB CADET 1450, 72, 86, 1211, IH #2 CART, IH 56" SNOW BLADE, COLLECTING CUB CADET ENGINES |
