Old 12-26-2013, 11:51 AM
im not an expert on ISO mounts: the way you figured to put them in seems right, but the actual rubber parts are definitely different than whats on my 1250...the bottom, or under piece is smaller, and tapered slightly....so if they are the wrong ones, maybe composition is too soft, or who knows...i think personally, im going to try and find something adaptable in polyurethane, if i have to replace them again...i have used energy suspension parts in my trucks and am a BIG FAN...anyways, i hope that you can get it figured out, hate to see a good cub go!!
Old 12-26-2013, 10:57 PM
bkw3614 bkw3614 is offline
That is a Quietline tractor. I believe that the newer K series Kohler engines did not have balance gears in them. If the oil dipstick goes straight down from the top of the engine, the engine does not have balance gears in it. If the dipstick is mounted on the side of the engine block, this engine would be designed for balance gears. The side curtain would not fit on the tractor if the dipstick was mounted on the side of the block.
With the vibration problem in the mid-throttle range, and less at idle and WOT, I am going to guess that the problem is in your ISO mounts. I replaced the mounts in my 1250 about a year ago and used genuine Cub Cadet parts. I was told to use the original bolts and leave 1-1 1/2 threads showing on the locknut. If I correctly recall, the instruction sheet says to tighten to 100 1nch-pounds, which, to me, is very tight. I used new grade 8 bolts, locknuts and washers from Caterpillar. Long story short, I tighten one turn at a time on each mount until I cured the vibration problem in my engine, and made the tractor fun to ride. YOur results may vary, but I believe I have four to six threads showing, depending upon which mount. Keep adjusting until you get it the way you want it.
Good luck.
Old 12-27-2013, 09:56 AM
cubfan's Avatar
cubfan cubfan is offline
Thanks to everyone for chiming in.It has a straight dip stick and that's grrrreat news that it doesn't have balance gears.I just assumed it did going by what I had read in previous post concerning QL's.I sure did pick a bad time to start this (lol) as everywhere Im calling to get parts is closed for the holidays.Even the online sites haven't returned any emails.One thing I am concerned with though.If one just tightens the ISO mounts till the vidration is acceptable doesn't that kinda defeat the .06-.12 clearance for the snubbers?Im ok with whatever works but just thought I would throw that out there.Thanks again
Old 12-27-2013, 01:47 PM
cubfan's Avatar
I finally got the Iso mounts and snubbers ordered.Got them through Parts Tree.Just a little over $100.00 for all of them.3-5 day delivery time.When I get home going to finish with the tear down and get into the steering column.Also ordered new tie rod ends for it and a new axle shaft.Those were gotten off of ebay.I think I may have found a new parts supplier.Pretty cool when you can be 1000 miles from home,have them send you a diagram and pick the parts you want.
Old 12-28-2013, 12:55 PM
cubfan's Avatar
I got home today and finished with the tear down.This is as far as Im going with that only because Im 100% sure the rearend and trans is in great shape.A good bath is in order at this point.
Old 12-28-2013, 02:45 PM
cubfan's Avatar
Thumbs down
Bath time.
Old 12-28-2013, 03:17 PM
cubfan's Avatar
I used Funk engine degreaser on it but it didn't come anywhere near as clean as I wanted it to.Does anyone know of a badass degreaser?I don't have a pressure washer and Im not fonde at all of a rag and soap as cold as it is outside.Anyways its back in the shop and now to the steering column.
Old 12-28-2013, 03:29 PM
bluesman bluesman is offline
Good luck.
Glad I've been following this thread. Learn something useful here.
I will attempt to address my procrastination problem while you wait.
Old 12-28-2013, 03:49 PM
Sam Mac Sam Mac is online now
I use Super Clean from Wally World. If it's nasty you may want to spray some diesel or kero on it and take it to the local car wash. I have been asked to not return to the car wash. LMAO
Old 12-28-2013, 06:09 PM
cubfan's Avatar
I got the steering column apart and cleaned up.Resurfaced the cam follower and cleaned up the mating surfaces.Now I just need for some parts to come in.
