Old 12-21-2017, 08:23 AM
Do as you wish, I myself,
would not impose on a person to do the machining it requires to set up a vertical block to horiz.usage,
when blocks are available,and reasonable priced.
Doing it yourself for self gratification, like building a ship in a bottle is something else, and rewarding.
Do it the easy way with a horizontal block!!
Doing the dipstick hole is a task, do you have a 16" long drill bit?
assuredly no.
believe me it is an involved process,with many steps.
I'm am not trying to make myself out here as a genius, just BTDT and I would not do it again.
it is not something you can fudge or get close enough.
Either it is done right or it goes bad in a hurry.
Just trying to help.
All that said,
I'd buy the MV, it is worth that in parts if in good shape.
Then look for a horiz.block & crank.
This time of the year parts are a little less costly due to lessor demand.
Old 12-21-2017, 08:46 AM
Gompers Gompers is offline
assuredly no.
All that said,
Well he’s retired and just does it for fun. I haven’t poked around his shop, but you’re probably right.
I’ve also got that kt17ii with a cracked block I could just get a new block for and rebuild too I guess. Probably be in it about the same either way.
Decisions decisions.
Thanks again! Very grateful for your expertise.
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240
Old 12-21-2017, 09:46 AM
here ya go:
epay 272966814468
dipstick, filler cap, fuel pump, cam cap ( important) oil pump,
& cover plate.
he also has a crank but with rods/pistons
just add Mv goodies and get a crank or shorten/ machine the mV crank.
Old 12-21-2017, 12:00 PM
I wouldn't waste the time to either rebuild the KT or do a vertical to horizontal conversion. That engine isn't worth the effort.
