#21
I have a soft spot for the QLs. My 1250 Is super loud, shakes, and needs new ISO mounts while. my 1450 Is nice and quiet and doesn't shake as QLs are known to. I hate how everyone turns them down. They are still an awesome cub cadet line. It all depends on what day of the week you buy them.
![]() Grandpa's 1961 "O" w/ mowing deck, 169, 149, 147, 1000, 125 w/creeper and 3pt, 1250 w/ 44A deck, 1650, Frankenstien 1250, Great Grandpas 1968 Cadet 125 w/original QA-36, CCC 1711, Model 2 tiller, QA-42 and a QA-42A Snowthrower, Cozy cab May not be as much as others, but we're still building our fleet! There are more to come! Connor |
#22
![]() If you get a Quietline that has the cradle fixed, good ISO rubbers, and no drive line wear (rag joints, hydro fan, and ...? someone else fill in these drive line wear parts), then rest assured that you shouldn't have any issues that other Cub's don't have.
-Ryan
#23
I've got a 109 and a 1650. The 109 is similar enough to the 149 to be a fair comparison - less hydro lift and 10 vs 14 hp engine, but I use it as an example of my experience near to a 149. My 1650 has a 14 hp engine in it, so it is basically a 1450.
IMHO: 149 is a dandy tractor. Hydro, wide frame, solid mount engine, easy access under the hood. If I had to consider everything on paper, I would take the 149 every time, however... 1450 is also a good tractor. I can't explain it, but inspite of the pain of dealing with the iso mounts, side panels, etc., once I got mine back together, it is really a decent tractor and IS quieter than my 109 or 126. I really like the looks of this tractor and it is very comfortable to drive. Hard to put a finger on it, but I just like it! I'd say the 1450 probably can be had a little cheaper than a 149. I'd say both have equal capabilities. I'd say once you get the iso mounts, etc., out of the way, you've got a long term worker tractor that is easy on the eyes in the 1450. So many tractors, so little time...
IH Cub Cadet 109 IH Cub Cadet 126 (2) IH Cub Cadet 149 IH Cub Cadet 1650 MTD Cub Cadet LTX1042 |
#24
I have one of each--149 and 1450 (and another 5 or 6 tractors...). I like them both. The 1450 is quieter IF you can secure all the tins. I like the electric clutch over the mechanical clutch on the 149. One less belt to wear out on the 1450 with the small starter. Many of the later 1450s (and other in that series) had auto releasing relief valves and larger 1 inch front wheel spindles.
I have a 1250, and priced the front snubber mounts at 13.00 for the set, and $26.00 for the ISO mounts each from Cub Cadet. Estimate 120.00 for everything and you go pick up at the dealer. There is a gent who makes the solid mounts from steel for a much better price. I happen to have my own diameter 70 duro stock and will be making my own ISO mounts from better rubber.
I don't have a 149, but I agree with all the other members that the QL Series is one of the best looking, and styled garden tractors IH made. I like the 149's, I like them all!
IH CUB CADET 1450, 72, 86, 1211, IH #2 CART, IH 56" SNOW BLADE, COLLECTING CUB CADET ENGINES |
#26
#27
Well said, Beautiful.
#28
Can't miss with either one in my opinion. I would personally go for the 149 though.
#29
The second valve section was an option. I believe they all had at least one for the Hyd. lift.
"If I can't fix it, I can screw it up so bad no one else can either" |
#30
Thank you guys sooooooo much for ALL the great feedback to my question. This is why I posted the question here on OCC!! I have a 149 that I think is great and was thinking of adding the 1450, but I'm glad I asked you guys first!!!! If the ISO mounts and the tin is as a prominent an issue as you guys have mentioned then I better think it over a bit. Thank you all, once again, for all your great help on this one.
.Quote:
Kenneth |
