Thread Tools
Display Modes
#21
My 149 has a PTO safety switch , right where he says his is.
How do i know ??? My 149 wouldn't start and i traced to the PTO safety switch. I wish i could get you a pic , it is buried anyhow , so it probably wouldn't show up. |
#22
Page 20 in the service manual shows a PTO Safety Starting Switch in the wiring diagram. Looked up the manual on this site , to lazy to walk out to the garage.
#23
Ok.... my bad.
![]() BUT, again, that is a SYMPTOM, not the problem. Start at the BATTERY and go from there. If it has 6V on BOTH sides.... THAT IS NOT WHERE THE PROBLEM IS! See R Bedell's post #9. The PTO safety switch is only on the START circuit. It wouldn't cause it to die suddenly. |
#24
Yes there is. And when depressed there should be 12 volts on each side with the key in the start position.
If memory serves, the orange/orange & black wire ultimately goes from the "S" on the Ign. switch to the small terminal on the solenoid.
#25
Sorry, didn't notice the third page...
#26
OK....it comes down to terminology and now I can see the confusion. The 149 does not have the traditional PTO switch. It does have a "PTO starting safety switch".
I agree, this safety switch would have NOTHING to do with the tractor suddenly going dead.
#27
OK, no biggie, I won't have to reduce the resolution for pictures. Sorry for the delay, slept in a little (so nice). First thing, gonna check for spark, will report back later.
#28
How do you plan to check for spark if the motor won't crank?
#29
good point. So back to the tests. I still have the ignition switch out, and when I test the molex connector for the ignition switch i get 4+ volts on the "ignition" and "starter" plugs, and 12+ volts on the "bat". I already mentioned 6+ volts on the PTO safety switch. I'm not sure these if these voltage drops would cause a running engine to quit or not. Any thoughts?
#30
I just cleaned up the ignition sw connectors and sprayed some deoxit in the female molex plug, turned the key and now get machine-gun clicking which, I believe, indicates a bad solenoid. Am I correct?
