Old 07-07-2013, 01:20 PM
jonjunk's Avatar
jonjunk jonjunk is offline
No I didn't get the 12 running any better I couldn't get the carb off because of the governor link and muffler I was going to clean it better ended up breaking the screws for the choke butterfly so I have to choke it the old fashioned way(just kidding the Choke is old fashioned) as soon as i get the 123 running imma rebuild the 122 and hopefully paint it
Anybody know if the tapered shaft will work ?
Or if it would be easier get the 14hp and put it into my grandmas 129 that has a warped head we think
122 PTO, lift, deck, weights, and chains clist pick
123 headlights no motor came with the 122
Stx38 free acquisition but its the wrong color works great though
Free craftsman gt 17hp Briggs Intek hydro
Old 07-11-2013, 04:14 PM
jonjunk's Avatar
theres a kbid auction ending tonight with a kohler 5000watt generator on it Im gonna hopefully get it for a good price the bad part will be loading it, then ill have the 123 running in no time, itll probably need a carb though because i think it is LP so not sure what they all have
Old 07-11-2013, 06:33 PM
jdroison jdroison is offline
Exclamation
the tapered shaft will not work with the pto, those are made for generators and some pumps. you need the straight shaft your old motor has.
Cub Cadets & IH tractors
1811 - 1090 hours
1872 basket case, rebuilding.
#1 tiller
1 Farmall regular
Old 07-11-2013, 09:10 PM
jonjunk's Avatar
Lost the auction for the kohler generator went for $170 which Is cheap but i missed my last vid that wpuld have been cool to have a cub cadet 123 LP even if that engine had a tapered shaft also which I assume it did, anybody ever made or seen a cub cadet actually run on propane seems like an easy conversion
Old 07-12-2013, 06:31 AM
jeepchicken5000's Avatar
there is a guy on youtube that runs his 982 cub on propane but you got to buy the whole setup and I don't think its very cheap. id just stay with gas, ive never really had any issues but I use stabilizer in mine, plus im getting better at clean carbs and tanks out
Old 07-12-2013, 01:56 PM
jonjunk's Avatar
I just thought it as a noveltythe generator motor came with the carb and regulator for LP so all it needed was a tank
Old 07-15-2013, 06:54 PM
jonjunk's Avatar
How hard would it be to use a steering wheel from a 715 IH combine I already took some of the switches including the ignition which ive decided not to use because i dont know how to rig it up for push button start because the key is only 2 positon, naturally the steering wheel is mint being the combines all came with cabs on just have to figure out how to get it off the combine might need the torch to cut the control pillar thing off
Old 08-17-2013, 12:20 PM
jonjunk's Avatar
There is a qa42a snowblower on craigslist near me for cheap i was wondering if that would fit a narrow frame the guy told me it came off his friends 128 so I'm not sure
Old 08-17-2013, 01:15 PM
Yes, it will fit a nf and a wf. The last A means it is adjustable.
Old 08-17-2013, 03:39 PM
jonjunk's Avatar
Even with the same mule drive ?
That's great news. He said it came off a 128 so my 12hp should be able to handle the big 42" right?
