#21
I'd say it could be possible that when the engine is running it could drive the governor gear off the cam gear with that much play. Did you reinstall the shims on the correct side of the cam shaft?
#22
Which timing mark on the crank did you use when you reinstalled the crank and the cam?.
It happens... I had a 7 hp have the same issue,changed out the gov gear with a known working one and it fixed the problem,who would of thought a metal one going bad.
#24
I've read this over a couple times now, the governor gear should push itself towards the block due to the helical cut. there should be a shim that goes between the block and the governor gear. the cam would push to the bearing plate side of the block. I'd find it odd if the governor gear was loosing contact with the cam . I've shortened cams before and shimmed them on the opposite end to advance cam timing. you have to take allot off to start to come off the gov gear. it almost has to be an adjustment issue. I know it can be difficult to hold the carb open, rotate the gov shaft and tighten the bolt on the gov arm without anything moving.
#25
To answer a few of your questions:
1. The crank/cam timing marks are correct. 2. The shim is behind the governor. 3. There is no binding of the linkage anywhere. Everything moves freely.
--- 5x Originals, one with rear PTO, 70, 2x 100's, one w/ creeper,2x 102's, 2x 122 w/creeper and rear pto, 2x 123's, 105, 125 w/ aux hyd,2x 73's, 126, 2x 147, 86, 2x 108's, 129, 2x 149's, 169, 3x 800's, 2x 1100's, 1250, 3x 1650's, 682, 2x 782's, 782D, 982 w/60" Haban, 1872 w/ Haban deck 2 Rear Tillers, 1 Snowblower, #1 cart and 2x #2 cart IH/Cub Cadet 79C Chipper 526 Front Tine Tiller Brinly plow, disk, grader blade |
#26
have you gotten anywhere with this?
#27
I have decided to step away from this one for a while. I have no ideas at the moment as to what might be wrong, and have several other projects waiting so Im moving a few of them through.
#28
might have an idea on this one. just ran into it this afternoon. when you tighten down the brass nut on the outside of the block does the cross shaft get stiffer? if so take the brass nut and file off a little on the threaded end till when you install it you have a little movement back and forth. it seams as you tighten down the brass nut it starts to pinch the cross shaft because of the spacer being in there.
#29
I am dealing with this exact issue with my 123. No throttle control at all above idle and it races away. Been through the service manual governor adjustment procedure a bunch of times and am comparing everything to my 127 set up as well which governs out fine just to make sure. I really hope we figure this out too.
