Old 05-06-2013, 08:16 PM
Mike
What model tractor do you need a brace for? At the moment it is designed for a Super and it looks like I will need to make some minor mods for it to fit a GT, no big deal.
Stopped at the welder today and he is running behind, seems a tree fell on his car last night. He said he will get it done tomorrow AM.
I have a Super with a broken front casting. 2082.
Got a buddy with the same tractor I told you about several months ago that tried a brace of his own design might want one.
Old 05-06-2013, 08:32 PM
Mike
Now you know those of us non Super guys will want one for our GT's.
Old 05-06-2013, 08:39 PM
Mike
As soon as I get the prototype on the 1572 for pics I will post them. Considering that you have one that is busted I will rush a set for you. Your tractor with a broken front mount will be a good test of the design. Shoot me a PM with a phone # and I'll give you a call.
For you GT guys I will get you covered ASAP.
Old 05-07-2013, 01:29 PM
OK Guys
Got the first prototypes done and installed on my 1572. I also made a short set that I think will work on the GT’s. Since this tractor has the older style 60” Haban I decide the use the stabilizer bracket for the front pickup point. I will make a small change in that for the production versions. Need to get some longer bolts because the plate is 3/8" thick. Not sure if these will work on the rear PTO type 3 point hitch tractors without some modification. I need to see some close up pics of how the hitch mounts to the rear.
Old 05-07-2013, 02:07 PM
Looks great, Sam!
Old 05-07-2013, 02:28 PM
Looks great Sam!
Old 05-07-2013, 02:39 PM
ajcombs's Avatar
ajcombs ajcombs is offline
Hey man looks great and should help for sure!
Old 05-07-2013, 02:52 PM
Grampie Grampie is offline
Traction Bars! Very nice There Sam! Now thats usin your Noodle! Otta work out pretty good!
Old 05-07-2013, 03:01 PM
squatch squatch is offline
I have a question on this. My Super has this rear plate on the frame.
It seems like it goes a long way to keeping the rear frame rails from squirming. My bolts and case are all good. Is it possible that this is all that is needed to keep these from working loose in the 1st place? I've only seen one super with the busted loose bolts. It didn't have the rear plate. Can anyone shed light on this.
Old 05-07-2013, 04:30 PM
After giving your brackets a second look, it appears that you don't have the front of the bracket bolted to the frame. Just that the bracket comes up UNDERNEATH the frame rail and that would still stop the frame twist in that area without unduly stressing the frame in other points.
If that's the case, good move on your part.
