Old 03-12-2013, 03:15 PM
samiam44 samiam44 is offline
I know kirk muffler mod- he gutted it and just put fg/mesh to get some dampening. I'm thinking of doing more after looking at Donaldson mufflers. I think I can get some 1.5 or 1.375 inch perforated pipe and do several chambers.
You want expansion, dampening, and reflection to be quite.
Yes, I think you can mill the head 050 inch and still be reliable. The most gains will be with good valve work. I ground my intake at 30 degree angle. You want a 3-angle with the valve contact to be on the outer most part of the seat. Ie, make it effectively large. Then you can taper and swirl polish the valves. The machinist I used did a lot of Cart engines.. thought it was a bit odd with my requests, but humored me. With a rebuild it should run really nice. I have mixed feelings about putting a cheater cam in them- I know I run mine at 3600 rpm all the time and it might work great- don't know.
Michael
Old 03-12-2013, 07:16 PM
fourinchdragslicks fourinchdragslicks is offline
So I can safely assume that no one has done or knows of a REPOWER with a DIFFERENT ENGINE with MORE THAN ONE CYLINDER that allows you to KEEP THE SIDE PANELS ON.
