Old 11-09-2009, 08:01 PM
MFP8055,
Its got to be the tubes just are not stretched out yet. Depending on the type of 23x10.5-12s you have (some are a little bit wider or taller) you should easily get between 7 and 8 gallons in with the valve stem at the 12:00o'clock position. Air them up to between 12 and 15 psi. and use it for a few days and try adding some more. I only have tubes in one of my tractors (jd) and they were in when i got it. So they were already stretched. Just my
Old 11-09-2009, 08:23 PM
CubQuest CubQuest is offline
Originally Posted by MFP8055 View Post
I added the washer fluid to my 23x10.50-12 tires Saturday. The chart claims that 7 gallons would fit. Maybe this is so based on total volume, but the best I could do was 4.5. the tire was mounted with the stem at 12:00. Tubes were in the tires and they were brand new and hence, a little stiff. Anybody ever get more than that amount in a tire? How did you do it?
I just put 6.5 gallons into 23x10.50-12 and I'm sure there is room for more but 13 gallons was all I had. I did it with the tires laying flat on the floor. The 1st 3 gallons per tire were quick and easy but after that I had to stop every gallon or to burb the air out, the last gallon took quite a while and I had to burp it several times.
How did you get the fluid in? pump, air pressure or gravity.
Old 11-10-2009, 09:41 AM
MFP8055 MFP8055 is offline
I used the "drill pump" previously described with the TSC valve stem-to-garden hose adapter. It worked well when vented every gallon or so. The Deestone tires seem just a bit narrow, and are 6 ply, so the internal volume may be a little lower than a tubeless standard 23X10.50-12. I had the same thoughts about the rubber being stiff. I'll run them this winter and next summer, when it's warm, take another shot at topping them off. I made concrete wheel weights which are in place now, so access to the stem is going to be a PITA. With a total of 75 lbs. per wheel in place already, I'll probably just leave it as is.
IH 1650, CC 1210, 1610 and Bolens 1257
Old 11-10-2009, 11:56 AM
MFP8055, we want pictures of those weights, a lot of us are always looking for good ideas...
Old 11-10-2009, 01:23 PM
jbollis's Avatar
jbollis jbollis is offline
X2 on the pics. I dont like my cement filled plastic ones, and refuse to pay top dollar for the cast ones.
joe
Sold everything but one.
Old 11-10-2009, 02:32 PM
I documented the process and will post pictures and the procedure in a new thread. Real busy right now, so it will be a few days.
Old 11-10-2009, 03:29 PM
Jeff122's Avatar
Jeff122 Jeff122 is offline
Default weights
I hope to get some pictures posted in a day or two. But here's one so you can see my concrete wheel weights. I used sonna tubes and plywood for the molds, and electrical conduit in the concrete for the mounting bolts. After they were dry, I gave them multiple coats of concrete sealer. It's a little bit of a PITA to get to the valve stems, but not impossible. The weights stick out quite a bit from the rims, but I wanted as much mass as possible. I estimate them to weigh about 30 pounds each.
Old 11-10-2009, 05:22 PM
Jeff122,
Not bad, you did a good job.
Would it have been possible to put something in the sonna tube to leave a void, so there would be room to get to the valve stem easier?
Old 11-10-2009, 06:25 PM
Jeff122's Avatar
Actually, the tip of the valve stem is about in the middle of the weight. I can remove the cap and put air in if I pull the stem out slightly with my finger tips. A longer valve stem or a 90 degree valve stem would eliminate this issue. If anyone is wondering, I used 1/2" threaded rod to mount these to the rims. Also, future pics will show how I added almost 200 pounds to the rear of the tractor.
Old 11-10-2009, 08:20 PM
IHinIN IHinIN is offline
Jeff, Those weights look pretty nice. I'm in the process of making some concrete weights too. I'm going to fill pieces of 8" i.d. corrugated plastic drainage tile and cover the ends with sheet metal so that it will hide the concrete and so it can be painted. They will be mounted with a 3/4" threaded rod thru the center of a piece of steel tubing set in the concrete. I've got some scrap steel pieces I'm gonna throw into the concrete too since steel is heavier than concrete. Using just concrete they would weigh right around 20 lbs each.
