Old 11-09-2012, 01:14 PM
Me too buddy!
Good thing I've stopped buying Cubs.....
I hear ya, John. I still have a bad case of the Yellow Fever though!
Old 11-09-2012, 03:05 PM
ajgross ajgross is offline
Inactive Member
Originally Posted by jr315 View Post
is there any mods i should do to make ethe tractor better?
Let's get this back on topic.
As far as mods, there really aren't much. In my opinion, the 782 was the best designed tractor they built! The only mods I know of would be to add a washer to the trunnion spring to stiffen it up a little bit. It helps keep the transmission at a constant speed. Other than that, they are pretty much the perfect garden tractor. Now, I think of it, power steering would be a awesome upgrade but a bit pricey. Plus it takes some modification to make it work. Or you could find a steering column out of a 1810/1811/1806. The 782 came with what we call a 2 turn column. Basically it take 2 turns of the column to go from one side to the other. The 18xx tractors had a 3 turn column making it easier to steer. Other than that, the 782 was perfect.
AJ
Old 11-10-2012, 05:36 PM
jr315 jr315 is offline
could u post some pictures of where i need to put the washer and is there alot of work to make it have power steering??
