#21
![]() Quote:
![]() Good thing is it still looks brand new, even after 4 seasons. ![]()
Josh Diesel Cub Cadets........... |
#22
Cool vid! Your 1450 runs good!
#23
![]() Quote:
![]() ![]() Better than a straight pipe, but not by much.
CC 1450, 44A deck, #2 tiller, 42" plow/blade CC 124 CC 1220 #2 Cart |
#24
On these mule drives, if I find one that has the angled pulley's can I just straighten them? Would you leave the spring tensioner or replace it with a bolt type tightener?
#25
Noticed some Hytran leaking around the left middle bolt on the rear diff cover. After reading prskier17's thread on his 1650. I wonder if mine suffers from the same broken piece around the bolt hole. Hopefully its just a bad gasket. I guess I will find out when I change the Hytran. Sounds like this is not uncommon on these tractor's. Anyone know what causes it?
#26
Usually over tightening or using bolts that bolts that are to long.
#27
I took the 1450 back to the orchard and did some mowing. Work's pretty good. Lot's of power and the old Kohler really smoothed out at the higher throttle setting. I didn't get any pic's with the tractor, but here is the orchard and the roadway thru the field to it.
#28
Great pics! Your 1450 did a great job.
#29
![]() Quote:
the pic. The OEM bolt length on those ISO's was 2.25", and you can never find those at the local hardware store. I bought my 2.25's online. |
#30
Thanks CC1650Dave, I'll check the bolt length next time I work on it.
