Thread Tools
Display Modes
#21
CADplans, nice drill press
![]() Clint, graded bolts were used. Want some pictures of the nice blue chips that came off ? ( very hot ![]() ~~~~~~~~~~~~~~~ I installed a set of the frankenstein bolts on cavmedic's 1450 and they worked perfectly ![]() |
#22
wow, that looks like an oldie, i've never seen one like that. details!!!! LOL jeff
'72 108 w/ 38" HIGH speed deck, '77 1200QL w/ homemade grader blade, '79 1450 44" grass tamer, '70 sears super 12 w/ 3pt , 19?? 100 w/ extra toys, 69' economy powerking 14 horse w/ FEL, 65' economy powerking w/ toys, 1982 allis chalmers 716 Jeff |
#23
![]() Quote:
It was initially bult for ultra precision work probably in the WWII era. From what I understand it will drill on location within a few tenths!! I have never tried that, it came with a set of boxed mics for the x and y axis'. I opened the box, closed it and set it up to drill holes. We use it with a self centering vice to minimize setup as most holes are drilled at the center of a parts width. The thing will throw out chips like a lathe all day long!! ![]() It is rugged, weighs over 5000 pounds, we paid less than $0.50 a pound for it. Almost as much fun to run as our CNC saw, Melissa!! ![]() And my CNC torch I built!! You can read about the torch here: http://www.sweetmk.com/2011/11/my-cnc-torch/ |
#24
They look backwards don't they?
#25
These are for the rear lift casting on the wide frames. Cavmedic's 1450 was the "test mule" and they worked/fitted perfectly when installed today.
If you were thinking of the attach bolts for the front implements / mule drives, then they would be backwards. |
#26
Not to hold the top casting in place they don't. Are you thinking these are for the mule drive on the frame?
#27
no I just looked at the thread depth blue chips means its taking the heaat away looks good
#28
I get blue chips also a lathe sure makes things easier
