Old 03-18-2012, 07:49 PM
TheIHMan's Avatar
TheIHMan TheIHMan is offline
AND it has the optional hour meter which is hard to find original.
Ten. According to the Kohler Service Manual. The engine I have is a 14 hp with a 16hp shroud...
Old 03-18-2012, 07:50 PM
Should have 10 Adam.
Old 03-18-2012, 07:56 PM
Well, glad I didnt pay too much for it. Im sure it will be hard to find the correct engine for it, but it might be possible. Well keep searching...
Old 03-18-2012, 09:15 PM
David Gallagher David Gallagher is offline
Good luck with your 169. I have 2 of them,1 running and another ready to put back together. It is the best Cub Cadet ever made. Plenty of power. Just a nice rig. You will enjoy it, but engine parts are hard to find and expensive.
Old 03-18-2012, 10:42 PM
149 - 498944's Avatar
149 - 498944 149 - 498944 is offline
Default Freshly Overhauled 16HP Kohler Engine
Thought you might like this picture...
Cub Cadet 149 (Restoration Completed 2012)
Cub Cadet 149
Cub Cadet 127
Front Blade
1A Tiller
38" Mower Deck
44" Mower Deck
48" Scraper Blade
Plow
spare 12 HP Kohler
Old 03-18-2012, 10:55 PM
Id like it even more if my engine grew another head bolt!
Old 03-18-2012, 11:46 PM
red56turbo's Avatar
Originally Posted by TheIHMan View Post
When they first came out with the 169 they had to use manual lift because they were short on the hydraulic lift setups. Once they got more hydraulic lift units they made it standard on the 169.
Actually, I think they ran short of hydro lifts towards the end of production of the 169's. All manual lift 169's had ported pumps. Dealers could get a factory upgrade to add the hydraulic lift to manual lift 169's. My 169 is a late one and originally had a manual lift on it.
The hour meter was also standard on all 169's from the factory. They were called Maintenance Minders.
Ryan,
Nice pics. Looks like you have a great start for a 169 restore. You'll find the correct engine, just keep your eyes peeled.
Josh
Diesel Cub Cadets...........
Old 03-19-2012, 05:37 PM
Dave01's Avatar
Dave01 Dave01 is offline
So for a prior owner to put a 14 HP in, they would have to also install the exhaust and heat shield? Is that it, otherwise a bolt in replacement engine?
Seems like it's worth making it run, if it will, and keep the 14 in until a 16 hp comes along.
1864 w/48" deck, 2084 w/54" deck + 54" blade, 3204 w/48" deck
Old 03-19-2012, 05:57 PM
TheIHMan's Avatar
I don't know. My Cub Cadet book Original Farmall Cub and Cub Cadet says that the first ones had manual could be either
