#21
The guy didn't think he had much and I did get it cheeeeap. I looked at another 782 with engine problems today. Is there issues with these KT17s? I've got a 73- 149 with boo koo hours and it's never been down.
1973 149 with 44" Deck, 782 with Simms cab, 1966 102 with 38" deck, 50" deck, 5 42" Blade, Brinly 8" 3- point Plow, Brinly 10' Sleeve hitch Plow, Brinly 12' 3-point Plow, 782 Pile, 2-38' Decks, QA-42A,1650 Roller, QA42 Thrower, Kubota BX 2360, 1970 IH one ton 4x4, one 1959 farmall cub restored, two 1949 farmall cub projects, cub grader blade, 5 sickle bar mowers , 1 set cutivators , 1 fast hitch plow, 1. 1950s IH hay rake |
#22
There was a oiling issue with the Series 1 KT's. The engine was pressure lubed, but they didn't pressure lube the rod journals. When you get it on a angle, it starts staving one journal of oil causing it to blow up. They fixed this issue with the Series 2 engines.
AJ
1980 [COLOR="Red"][/COLOR]482- Stock 1981 [COLOR="Red"][/COLOR]582- Mag18, Sleeve Hitch, Spring assist 1979 [COLOR="Red"][/COLOR]682- Mag18, Sleeve Hitch, Spring Assist, #1 Tiller 1980 [COLOR="Red"][/COLOR]782- Mag18, Sleeve Hitch 1983 [COLOR="Red"][/COLOR]982- Stock, Fully Optioned |
#23
yeah I have ran across a couple people like that. They think the tractor is worth 3 times the amount its really worth just because it says Cub cadet or International that its worth at least $500 not matter what condition its in....I have seen a tractor in that shape been outside and the motor was blown and the guy wanted $600 for it
#24
I have never tried it, so somebody else might chime in on it, but your engine case might be salvageable. Since the hole in it is only "about the size of a dime", you can probably patch it with JB weld, or maybe drill it out to perfectly round and plug it. Your crankshaft might be fine, or maybe just need a re-grind on the rod and main journals. The rest can be had on the used market, if you can't find them new. I'm betting you can rebuild it for $3-400, rather than spending upwards of $1200 for an engine somebody else rebuilt, or $2000 for a new one. Then again, if I could afford it, I'd be re-powering with one of the newer OHV V-twin engines.
Since I have a KT17 Series 1 in my 682, I'm going to start trying to cross-reference parts and see whether I can use parts from other engines to replace NLA parts. Right now it's running fine, but eventually I'll need to overhaul it. I'm thinking that parts, such as rods, pistons, heads, cylinders, and valves are probably pretty similar between the various iterations of the Kohler flathead twins and might be adaptable. Might even be able to use some B&S parts. Try this link, somebody posted a while back. Might be a place to start: http://kustomsmallengine.com/main.sc
Tony Stafford, VA 1650, 682... |
#25
You can use Magnum rods in a Series I if you really want to, you just have to drill the oil hole in the rod cap. One of the blown Series I engines I have had was blown because somebody rebuilt it with Magnum parts without putting the oil hole in the rod caps...you can imagine how long that lasted...
#26
You guys sure got me thinking. Sounds like about what I suspected that maybe the hole could be plugged, filled, or even welded. My main concern is the crank.
Thanks Guys,
#27
![]() Quote:
#28
We want pics!!
#29
I know alot of the guys I pull with weld holes in the blocks all the time on various types of engines under very extreme conditions, and seem to last. Is the block aluminum, if so that would be much easier to patch. Also since I couldn't make it out last night WE WANT PICS!!
129 Plower; 72 pile;122 daily driver, 2-42inch blades 42 inch deck- 06 GMC 1500 4wd- 1964 farmall 706 |
#30
A 'fix' for what?
If both engines are apart in buckets it should be pretty easy to tell if they are Series I or Series II...Series I crankshafts don't have an oil passage through the mains and rod journals, and the Series II engines do. Also, the camshaft on a Series I has a couple holes drilled radially through it in line with the connecting rods to spray oil on them. |
