Old 11-14-2011, 08:58 PM
Originally Posted by gillis51 View Post
Thanks all. Now I need to order some new front sneakers.
All the more reason to get some tri ribs or V61's...
Old 11-14-2011, 09:01 PM
cub123's Avatar
cub123 cub123 is offline
Best to just leave it stock, I know it looks a little odd at first, but your Performance will be much better, and you won't risk messing up your spindles.
Old 11-14-2011, 09:03 PM
cub123's Avatar
Post
Those v61s are awesome!
Old 11-14-2011, 09:09 PM
gillis51 gillis51 is offline
I'm looking for a nice turf front & rear. What are the function of rib tires
Old 11-14-2011, 09:21 PM
Traction!!! Turf tires suck at traction in turns. Just my opinion.
Old 11-14-2011, 10:54 PM
dieseldan123's Avatar
I hate turf tires. Once you get a set of V61's and rear ags you will never want to change that setup ever again! (with the exception of snow traction then trufs work much better) Plus the Ags and ribs dont do any more damage to the ground than turfs in my opinion with the benefit of superior traction in either wet or dry conditions.
1967 IH Cub Cadet 123
1978 IH Cub Cadet 1650
19?? IH Cub Cadet 682
Old 11-16-2011, 02:47 PM
westofb's Avatar
westofb westofb is offline
I just read your thread, my 149 is exactly the same way, being that the right front wheel has slightly more positive camber than the left. I put on a set of narrow front wheels and tri ribs, that makes the difference in camber from side to side even more noticeable. I first suspected that something was bent as well, but after close examination of both spindles, I am sure they were just made that way, I also compared them to several parts QL's that i have, and all of them had more right side camber. I centered my steering when I put mine back together, but remember reading that out of the factory the steering was not centered, the tractors were designed to turn tighter to the right to make trimming around obstacles in the yard easier, perhaps that is why the right side has more camber than the left....to make sharper right turns...that is my guess why they differ.
Jeff
Brookfield, MO
________________
Old 04-09-2012, 10:11 PM
105_Tom's Avatar
105_Tom 105_Tom is offline
Here's my 782 with the bends... I guess i'll just leave it alone, it does turn mighty nice like this. New tires are in order, though. I'll just have to keep that length of pipe away from the spindles while the wheels are off..
Tom
105, 149 w/44A, #2 & #4 carts
782 CCC Red w/44C
1512 Smoker w/50C, 450 Blower
2072 w/60" Haban
IH/Lawnboy 3322 Pusher, Scag TT 61"
JD 455, X495, Kubota 2150, Gravely 450, 812
Old 04-10-2012, 08:27 AM
149 - 498944's Avatar
149 - 498944 149 - 498944 is offline
Default tri rib
I put tri-ribs on my 149. I was sceptical at first but glad I did now. I can steer with one finger. You'll also notice from the picture below that the tire normally rides on just a small 1" band (easy on the turf) but will dig in if you get into softer stuff (mud, snow, ect).
Your chamber looks normal - I'd use your manual and make your adjustments - I set mine lock to lock and the turing radius is great and smooth. Front tires clear fine.
Cub Cadet 149 (Restoration Completed 2012)
Cub Cadet 149
Cub Cadet 127
Front Blade
1A Tiller
38" Mower Deck
44" Mower Deck
48" Scraper Blade
Plow
spare 12 HP Kohler
Old 04-10-2012, 09:08 AM
TheSaturnV's Avatar
That's the first close up outdoor shot I've seen of your 149 since you got it done. Whoa that thing came out nice.
