Old 10-29-2011, 07:50 PM
LarryW's Avatar
LarryW LarryW is offline
Well I drove it around about 20 minutes today pushing leaves and apples around with the JB. I guess I'm ripping the rear end/pump back out tomorrow. Cant stand not having it running. I have a full day to work on it so I should be able to swap my old one back in. The input shaft seal is leaking pretty bad. I assume there is probably a bearing there that is also bad. The axles shift in and out a lot too for some reason. Probably better see whats going on there too.
Cub Cadet 147 2050041u340160
42" Mower Deck, Snow Thrower, Tire Chains and Weights, Rotary Tiller 1, Brinly Sleeve Hitch, Brinly 10" plow, Johnny Bucket Jr.,42" QA NF Dozer Blade.
Cub Cadet 1872 SGT
60" CCC deck.
Parts 129 future plans =ported pump for 147, cast iron rear for 1872,129 frame and steering axle= ?wagon?
Old 10-30-2011, 11:30 AM
Axial play in the axles is normal. There is nothing to keep them from sliding in and out slightly.
Just change the seal...that's probably easier and faster than swapping the rear again. What makes you think the bearing is bad, too?
Old 10-30-2011, 05:26 PM
LarryW's Avatar
I couldnt get to the seal very easily with it in the tractor. Its not really that big deal to swap them. I timed taking the ported one out and did it in 30min. And that is with spending probably 10min searching for the extension I couldnt find. It was hiding in the tool box all along, lol. I messed around with some other issues before I put it back in. Fixed the trunnion. Seems to work good now and should last. Hairpin clip sheared off in my 3pt lift block on the arm. Made a clip with a hanger. I'll see how long it last. I have a problem with the relief valves dimple stuck in. The ones that go in to push it. I took them out and tried to push them back from the inside but they are stuck. Would they pop back up when trying to drive it? I swapped them out for now. Test drove it and its all like it was before my hydraulic idea, lol. Well with a few things fixed I guess. Now Im thinking back about the adding a pump idea. If only the saginaw pump spun the other way....
Now time to carve some pumpkins with the kids!
Cub Cadet 1872 SGT
60" CCC deck.
Old 10-30-2011, 05:31 PM
You've been busy, Larry. Enjoyed your pics.
Old 10-30-2011, 06:18 PM
CHWNY's Avatar
CHWNY CHWNY is offline
larry, you could turn the pump around the other way, EG. instead of the pulley facing forward/ pulley facing rearward... if there is enough room. Just a thought.
Clay
Old 10-30-2011, 10:00 PM
Sugarmaker's Avatar
Larry,
Man your not afraid to tackle about anything! Thanks for posting the picture. Gives me ideas of what to look for as parts get worn.
I never thought of making my own R clips Nice work.
Hope the pumpkins came out nice for the little ones!
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 10-30-2011, 10:21 PM
LarryW's Avatar
Yea I thought of that but then the SG is in the way to get the pulleys lined up. I need to investigate maybe mounted it under the hood in front of the engine maybe?
Larry,
Regards,
Chris
Thanks Chris, Those R clips get pricey. Hangers are free. Not sure how well they will last but Im going to find out.
Cub Cadet 1872 SGT
60" CCC deck.
Old 04-13-2012, 08:28 PM
Sugarmaker's Avatar
Where's Larry?
I need some one to swap rear ends in minutes.
Regards,
Chris
Old 04-13-2012, 09:04 PM
LarryW's Avatar
Where's Larry?
Regards,
Chris
Im alive, just caught up in life. The 147 is still running good. Used the rototiller for the first time few weeks ago. Worked good. Still no hydraulic lift though. I still need to get a new seal for the input shaft on my ported rear end. And I was thinking... That came out of a 129 with no engine. I recently got an old Tecumseh 18hp oh180. I was kind of thinking of sticking it in the 129. Then go back to an auxiliary pump idea on the 147. If I do, it wont be for a while though. Trying to get the house ready to sell so I can get a little bit of land, garage, and hopefully a pole barn too.
What happen to your rear end?
Cub Cadet 1872 SGT
60" CCC deck.
Old 04-14-2012, 09:37 AM
Sugarmaker's Avatar
Larry,
Good to hear from you. Great you have a life. some of us get consumed with Cubs. That's about where I am right now. Based on my past I will ride this Cub wave about 5 years then it will taper off some.
Really hope you get the land and the pole barn! Im pulling for you. I also would love to build another building to have as a shop/ big garage.
I have a thread started on "Sugarmakers 252 4x4" I have grandiose ideas of building a custom Cub 4x4 articulated with two hydros. Well neither is ported so I have been trying to figure out the next moves. Don't really want to buy another tractor for parts.
You had done a lot of rear end swapping and it kept coming up in the search for ported hydros.
Hope things are good!
Regards,
Chris
